Go to Post Success in this game comes from a wealth of ideas and good engineering, not deep pockets. - Karthik [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 07-02-2011, 20:34
newkidd-sagar newkidd-sagar is offline
FRC #1241
newkidd-sagar is an unknown quantity at this point
Re: CAN from scratch
If we use the Black Jaguar method, can we let that Jaguar have a function like controlling one motor? Or is it required that that Jaguar be left alone only as the CAN Bus Master?
Thank you.
Unread 07-02-2011, 23:00
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
The Black Jaguar can also control a motor.
I've seen no data to indicate that using this Jaguar to control a motor will impact the performance of your CAN bus.
-- Marshal Horn
Unread 08-02-2011, 00:19
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
The only exception to this is I would recommend against using the bridging Jag to control a high current motor (like a drive motor) that may potentially trip a breaker. If any other Jag trips a breaker, the rest of the Jags on the bus continue to function since the CAN bus is wired through on the PCB. If the bridge Jag's breaker trips, the rest of the CAN bus is isolated from the cRIO so all motors will stop.
-Joe
