Go to Post Code doesn't break. It reacts exactly the same time every time. When something new happens that never happened before, it's because the mechanicals, electricals or drivers gave the code some new stimulus that wasn't tested before. - GaryVoshol [more]
Unread 07-02-2011, 19:11
384drtysteve101 384drtysteve101 is offline
FRC #0384 (Sparky)
384drtysteve101 has a little shameless behaviour in the past
C-rio old vs new
Our team 384 has a 2 year old c-rio, and we wanted to know if it could last another season, as we are trying to budget our money for the future, would there be a considerable difference in using a new c-rio vs a 2 year old c-rio? Plus what is the lifespan of a c-rio just for future reference?
Unread 07-02-2011, 19:56
Re: C-rio old vs new
The FRC cRIO's are all the same. They haven't changed from 2009.
They last a long time.
Unread 07-02-2011, 21:45
They last even longer if you follow the cleaning instructions and install provided gaskets that keep aluminum shavings form bouncing around amongst the electronics.
Greg McKaskle
Unread 07-02-2011, 22:11
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Greg McKaskle
We use the gaskets, but what are these cleaning instructions you speak of?
Unread 07-02-2011, 22:43
How Do I Clean My cRIO-FRC and Install Protective Gaskets?
Unread 07-02-2011, 22:54
FRC #0384 (Sparky)
so if we clean ours up and protect it should be able to last for little more while, cause it is banged up a bit, i can post a picture or 2 on here to give a close up...
Unread 09-02-2011, 06:50
Post a picture. If pins are bent, you probably want it fixed. If there are holes drilled in it or other mods, it won't pass inspection at an event. The RMA process is quite fast, but this is typically for units that aren't functioning.
Greg McKaskle
