Go to Post Why do it the hard way if you don't have too? - ChrisH [more]
Unread 07-02-2011, 15:13
Peyton's Avatar
Peyton Peyton is offline
Electrical Captain 1591
FRC #1591 (Greece Gladiators)
Team Role: Electrical
Peyton is an unknown quantity at this point
Potentiometer
is there any restrictions to using a Potentiometer on our robot?
Unread 07-02-2011, 15:18
2611.Shooter 2611.Shooter is offline
Programmer
AKA: Andrew Lavery
FRC #2611 (Vectors)
2611.Shooter is infamous around these parts2611.Shooter is infamous around these parts
Re: Potentiometer
just wire it with the correct gauge wire for the breaker, and connect it correctly to the cRIO, not a motor controller. Oh and make sure the parts are under the $ limit. other than that I think you will be fine.
Unread 07-02-2011, 15:39
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Potentiometer
What are you planning to use the potentiometer for?
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 07-02-2011, 15:42
jtdowney jtdowney is offline
Boiler Up
AKA: John Downey
FRC #4302 (Robophins)
jtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant future
Re: Potentiometer
Typically potentiometers are going to be wired into a port on the analog breakout which provides power and is already downstream of a breaker.
John Downey
Lead Robot Inspector - Purdue IndianaFIRST District
Whitney Young Magnet High School/Robophins (FRC 4302) - Mentor (2013-current)
Midwest Regional Planning Committee - Member (2012-current)
Boilermaker Regional Planning Committee - Member (2011-2014)
Robot Inspector (2008-current)
Purdue FIRST Programs - Staff Advisor (2008-2011)
Lafayette-Jefferson High School/Precision Guessworks (FRC 1646) - Mentor (2006-2011)
Unread 07-02-2011, 15:46
Programmer
AKA: Andrew Lavery
FRC #2611 (Vectors)
Re: Potentiometer
that works too, just another way of saying meet the wiring resrictions! (hey, mebbe its a ginormous one and needs 10 amps or something )
Unread 07-02-2011, 17:55
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Re: Potentiometer
Actually, it would be a fairly tiny one by Ohm's Law, assuming we're talking 12V since its through a breaker
V = IR
12 = 10R
R = 1.2 ohms
Our pots are nearly 5000 times 'bigger'! Of course, I'm just being silly now.
Back on topic, why do you say not to connect it to a speed controller? The position control mode on Jaguars can use the potentiometers (though I don't personally find it actually works that well).
EDIT:
Actually, since you'd be dissipating about 120W, you would need a fairly large physical pot to absorb that kind of heat!
Ok, really I'm gonna put on my serious face now
Matt
Matt Krass
Unread 07-02-2011, 20:42
Ted Weisse's Avatar
Ted Weisse Ted Weisse is offline
AKA: xMentor/Inspector/Referee
Ted Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of light
Re: Potentiometer
If you are asking if you can use a potentioimeter the answer is yes. If you are asking how to connect it check the following FIRST document:
http://usfirst.org/uploadedFiles/Rob...out%281%29.pdf page 5 for this:
How do I connect a potentiometer?
Connect the wiper to the input pin – Top row.
Connect the other two pins to +5 and ground – Middle and bottom rows.
As for the Power required if you use a 1kΩ you would only dispate 144 mW at 12 volts and with a 10kΩ of course 14.4 mW. 1/4 potentiometer would be fine.
A good 10 turn pot works wonderful for positioning feedback.
If I am not for myself, who will be for me?
If I am not for others, what am I?
And if not now, when?
-Rabbi Hillel
Jewish scholar & theologian (30 BC - 9 AD)
Unread 07-02-2011, 20:59
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Re: Potentiometer
We found an old pot in our junk drawer that we are using to get feedback for our arm. Why would you want a sensor that can turn 10 rotations when your arm may only move 180 degrees. Aren't you using a small range of the possible output voltage?
Unread 07-02-2011, 21:01
Ted Weisse's Avatar
Re: Potentiometer
So true... A 300 degree one should be fine for most apps but I was thinking of a tower type of application that would have multiple motor rotations. One train of thought problem...
-Rabbi Hillel
Unread 07-02-2011, 21:10
wilsonmw04's Avatar
Coach
Re: Potentiometer
And I didn't think of using it on a idler or a sprocket. Can't wait to try that out on the next bot :-)
One more thing. I was expecting the output voltage to be linear (constant angle/voltage) but we found that not be remotely true.the first 40 degrees give us roughly a change of .3 volts but the next 45 degrees gives us a change of 1.7 volts. Is this normal?
Unread 07-02-2011, 21:20
Ted Weisse's Avatar
Re: Potentiometer
One analog input vs many digital inputs... I'd go analog...
-Rabbi Hillel
Unread 07-02-2011, 21:48
Re: Potentiometer
It sounds like you picked up a "log" or "audio taper" pot. They're used as volume controls. We accidentally mounted one on our 2004 robot's wrist joint, and it was ridiculously difficult to program for.
If I were you, I wouldn't use it. Get yourself a "linear taper" one. You'll be a lot happier.
Unread 07-02-2011, 21:52
Retired Starman Retired Starman is offline
FRC #3573 (Ohms)
Retired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant future
Re: Potentiometer
Not all pots are linear. Some are called "audio taper and have a logarithmic function to adjust sound volume so turning the pot approximates what your ear perceives as linear. I've also run into some very strange special purpose pots made on the surplus market. These have a very odd response. Pots aren't that expensive. Go buy one that's linear, and of good quality if your arm's position is going to depend on it. Remember, if you are using a feedback circuit to help drive your arm, then the quality of the pot becomes a safety issue!
Unread 07-02-2011, 22:13
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Potentiometer
Originally Posted by I_404d_ur_b0t View Post
Ignore the troll. (location listed as /b/, ridiculous suggestion, rookie year 1919, etc.)
Unread 07-02-2011, 22:15
wilsonmw04's Avatar
Coach
Re: Potentiometer
Originally Posted by PAR_WIG1350 View Post
Ignore the troll. (location listed as /b/, ridiculous suggestion, etc.)
before that it was "4 chan /b/ board" but agreed. The first rule of internet usage: Never feed the trolls.
