Go to Post It is often less about what you say, and more about how you say it. - IKE [more]
Unread 07-02-2011, 22:59
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
pic: Multi-state switches
Unread 07-02-2011, 23:01
JimWright949's Avatar
JimWright949 JimWright949 is offline
The Owen Day of Seattle
AKA: Jim Wright
FRC #4542 (Titanium Talons)
JimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to behold
Re: pic: Multi-state switches
Hey Mike,
Like you and your team a lot (after all, our schools share the same first name), however could you give a few words on how this voltage divider works for us?
-Jim
Unread 08-02-2011, 03:04
Ted Weisse's Avatar
Ted Weisse Ted Weisse is offline
AKA: xMentor/Inspector/Referee
Ted Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of light
Don't know exactly his original plan but the circuit on the left is appears to be a simple digital on/off. The one on the right could be used with the analog input to sense two different voltages (1.67V and 3.33V) and possible options in your program.
If I am not for myself, who will be for me?
If I am not for others, what am I?
And if not now, when?
-Rabbi Hillel
Jewish scholar & theologian (30 BC - 9 AD)
Unread 08-02-2011, 08:11
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Both are still dual state. Use the one on the left as there will be some floating voltage on the one on the right that could cause unexpected behavior of their robot.
The one on the left has a pull up resistor to keep the voltage steady, even through transition.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
