Go to Post Just wanted to know some of your favorite physics and math equasions during build seasions thanks. mine is pathagriom therom - team 3311 [more]
Unread 07-02-2011, 17:01
Sh1ine Sh1ine is offline
FRC #2791
Sh1ine is on a distinguished road
Horse Power
Does anyone know how much HP is created by a CIM?
Currently we have 2 running in a custom transmission with a 7.1:1 reduction.
Unread 07-02-2011, 17:44
2611.Shooter 2611.Shooter is offline
Programmer
AKA: Andrew Lavery
FRC #2611 (Vectors)
2611.Shooter is infamous around these parts2611.Shooter is infamous around these parts
Re: Horse Power
340 watts = 0.45594751 hp
(confirm watts?)
Unread 07-02-2011, 18:37
BHS_STopping's Avatar
BHS_STopping BHS_STopping is offline
The Freshman
FRC #0842 (Falcon Robotics)
BHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant future
Re: Horse Power
Certainly no more than 480 watts, since the CIMs can theoretically consume 40 Amps (before the breakers trip) over 12 volts, which equates to 480 watts (Power = Current * Voltage). However, due to losses from heat (which is quite substantial, just try to put your hand on a CIM after a match) this number is probably much lower.
[/The Freshman]
Unread 07-02-2011, 20:03
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Re: Horse Power
What Shooter said, although I believe the max power is 343 watts at 66 amps. After gearbox losses, It's likely to be closer to 280-310 watts per motor, or .375-.415 HP per motor.
Attending: MN Duluth Regional
Unread 07-02-2011, 21:01
FRC #2791
Re: Horse Power
Thanks. One more, how do I find out how much torque is applied after the gear box?
Unread 07-02-2011, 22:31
WPI Freshman
AKA: Alex
Re: Horse Power
You'll have to be more specific, as the torque output by the motor will be dependent upon the current being applied to the motor, which is then dependent upon the voltage and spinning speed, which itself is based upon what resistance it encounters and the torques being applied.
Unread 08-02-2011, 00:24
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Re: Horse Power
http://usfirst.org/uploadedFiles/Rob...rves_Rev_A.pdf
Torque is on the bottom, and you'll probably want to look at current. Since you can't apply more than 40 amps, you'll get about 120 oz-in of torque.
Unread 08-02-2011, 00:48
Re: Horse Power
You are assuming that the breakers will limit the current to 40 amps, or blow instantaneously at 40 amps. That is not true. You can draw much more than 40 amps for short periods of time. It is not a good idea to require more than 40 amps of current for extended periods of time, because eventually the breakers will heat up and blow, and the CIM will start to get rather hot.
Unread 08-02-2011, 00:56
Re: Horse Power
Guys,
40 amp breakers (actually all breakers on the robot) can withstand short periods (seconds) of 600% over rated trip current. CIM motors stall at 133 amps which is well below the 240 amps that would instantly trip the auto resetting circuit breaker. The breaker resets almost instantly.
Unread 08-02-2011, 13:36
D.Allred's Avatar
D.Allred D.Allred is offline
FRC #4451 (Rat Rod Robotics)
D.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond repute
Re: Horse Power
I assume you are designing a drive train and need to determine load on the system at that gear ratio. Load depends on several factors. For FRC drive trains, most people use JVN's Advanced Drivetrain Calculator. You can find the spreadsheet and presentation file at the link below.
http://thinktank.wpi.edu/article/5
