Go to Post High heels on a Segway takes quite a bit of adjustment - as I learned the hard way. - Jessica Boucher [more]
Unread 08-02-2011, 03:25
Hellfeier675's Avatar
Hellfeier675 Hellfeier675 is offline
FRC #0675 (Tech High Robotics Syndicate)
Hellfeier675 is an unknown quantity at this point
Re: pic: 675 Teaser 4
That big sprocket is even overkill (we're hoping) for the load that we will be putting it under .. thank you solid works It's pretty thick aluminum and the way that it will be torqued is not in the standard way, which is why we were able to have the spokes be as thin as they are.
Also we were shooting for overkill on the sprocket, because those things weigh about 1.5 lbs each so we thought we might as well put in some redundancy while we're at it since it's costing us nearly nothing in weight to do so.
Those inverse tapers are for something that we're doing for our drive which if I remember correctly I haven't seen done before on a robot. We're excited to see how it all comes together still.
-"Guys it's so inconvenient, Delphi is down at 3 am.... Hey I was bored last night!"
