Go to Post Can't we also care about and celebrate the processes, the professionalism, the experience of healing? - Taylor [more]
Unread 06-02-2011, 09:50
pmalmsten pmalmsten is offline
pmalmsten is on a distinguished road
Re: Smart Dashboard - What do you think?
Hi Everyone,
I'm pleased to announce that a new version of the Smart Dashboard client has been posted, version 0.6.0. Here are the release notes:
Smart Dashboard Client 0.6.0
* Added Compass widget. This may be selected for use with any numerical
  data type.
* Added LinePlot widget. This may be selected for use with any numerical
  data type. It may be resized by changing its widget-specific preferences.
* Added snap-to-grid view option. When enabled via the "View" drop down menu,
  all subsequent widget dragging will "snap" to a grid to ease placement.
* Added logging to a CSV (Comma Separated Values) file support.
	- This may be enabled via the GUI preferences dialog ("File" -> "Preferences").
	- Three values are logged: The time in milliseconds since the logging began, the name
	  of the field being logged, and the string representation of the field's value.
	- All timestamps are tallied according to the client computer's local clock (not the robot's
	  clock). Maximum sample time resolution is approximately 20 milliseconds. Samples sent more
	  frequently than this will be queued for transmission to the client and will therefore
	  be marked with very similar timestamps.
	- Logging is automatically restarted when the dashboard is opened if it was previously
	  enabled. It will continue to record all key-value pairs until it is disabled
	  or the dashboard is closed.
	- When logging is enabled, the target file will be overwritten whenever the GUI
	  is restarted. If a particular log is important to you, copy it to somewhere
	  safe before restarting the dashboard!
* Fixed crash when video display is enabled when the robot camera is configured for high
  resolution video.
* Fixed bug where redundant fields are displayed on the dashboard GUI when a robot is
  restarted.
* Fixed bug where changing a widget to another widget type (such as TextBox to SimpleDial) would
  often cause it to be moved when it shouldn't have been.
* Reduced memory usage of robot video display feature.
  Note: Save Files from Prior Versions are Incompatible
Unfortunately, due to the current architecture of the profile saving and loading
routines, save files generated by a prior version of the dashboard are not compatible with
this version. We apologize for the inconvenience and plan to avoid this restriction in the
future. For the time being, however, please re-create any/all profiles with the newer
version of the client.
As usual, the latest version of the client can be download from the FirstForge page: http://firstforge.wpi.edu/sf/go/proj...tdashboard/frs
Radical Pi, I was just recently discussing that idea with some of my colleagues the other day. We will investigate that feature; it sounds quite promising.
Thanks for all of your feedback everyone! I'm pleased to have a release for you which delivers as many of your requested features as it does.
Enjoy,
~Paul Malmsten
Unread 06-02-2011, 11:32
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Originally Posted by pmalmsten View Post
  data type.
...awesome...
resolution video.
Aha! I was having this issue and thought I would just wait until the next version, you have succeeded!
Unread 08-02-2011, 03:50
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Also, if any of you are interested in submitting patches to the client side code, I just posted a zip of the source code Net Beans project. Unfortunately, anonymous version control access is not available on FirstForge, but I would be happy to look at patches.
Anonymous, no, but you can access it just by logging in to FIRST Forge (i.e. not a member of the project) if you configure the permissions of the project as such. That is the state of the SVN server in the WPILib project.
-Joe
