Go to Post So why are we trying to go to Mars? It's because it's bigger, better, and bolder. Doing what nearly no other team can do, and defying all those who say it can't be done. That reward is a lot more than 9 points. - Mike [more]
Unread 07-02-2011, 23:37
Re: Deploying the minibot!!
According to the Q&A I linked and <G22>, if the Minibot crosses the deployment line while deployment is happening and while it's still in contact with the Hostbot, the tower is disabled.
Originally Posted by Manual, Section 1.6
DEPLOYMENT – the act of positioning a MINIBOT on a TOWER. DEPLOYMENT starts when the MINIBOT breaks the vertical projection of the TOWER BASE circumference. DEPLOYMENT ends when the HOSTBOT is no longer in contact with the MINIBOT. (Related form, DEPLOY, verb)
From the End Game rules:
Originally Posted by Manual, Section 3
<G22> HOSTBOTS may not contact their ALLIANCE’S MINIBOT while any part of it is above the DEPLOYMENT LINE. Violation: TOWER is disabled.
Deployment only has one definition, as seen above.
So, to answer your questions in order:
1) When does the Deployment Line become effective, before or after the Minibot is attached to the post?
A: Before. It's kind of hard to initially break the vertical projection of the base and be attached to the post at the same time.
2) Is the volume defined by the vertical projection of the base and the plane at the same height as the deployment line a non-entry zone unless the minibot is below the line?
A: Yes. See the Q&A that I linked earlier.
The other question I'd have, that doesn't seem to be answered anywhere, is: If a robot's deployment mechanism requires the Minibot to go over the Deployment Line before Deployment (as defined in Section 1.6) begins, is this legal provided that when the Minibot enters the vertical projection of the base, it is entirely below the Deployment Line?
As written now: Appears legal (pending somebody asking Q&A).
As could easily happen: Appears illegal, depending on exactly how strict someone is at calling going over the Line.
Unread 08-02-2011, 08:11
GaryVoshol's Avatar
Cogito ergo arbitro
A strict constructionist would say that the new wording of <G22> means that the MINIBOT can never be above the DEPLOYMENT LINE while in contact with the HOSTBOT - regardless of whether the MINIBOT is being DEPLOYED or not. In other words, you cannot store the MINIBOT on your HOSTBOT if any part of the MINIBOT is above 30" from the floor.
Someone will have to ask the GDC if this is the interpretation that they intended when this rule was revised.
(since 2004)
Unread 08-02-2011, 10:42
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
G22 is under the 3.1.5 END GAME section, which begins:
<G18> All TELEOPERATED PERIOD rules apply, except as modified in this section.
Clearly, G22 applies to the end game period only.
If they need to clarify anything, it's what will happen when a high carrying HOSTBOT fails to lower the MINIBOT before the END GAME begins.
This message is hidden because Jack Jones is on your ignore list.
Unread 08-02-2011, 11:39
mathking's Avatar
mathking mathking is offline
Coach/Faculty Advisor
AKA: Greg King
FRC #1014 (Dublin Robotics aka "Bad Robots")
mathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond repute
I think Jack and Gary's points both imply a need for more clarification from the GDC. On Jack's point: What if a team stores their Minibot high (say on a ramp) and decides not to deploy it (and never comes near a tower once the END GAME commences)? Because as the rule is written now that would clearly be a violation. But I find it difficult to believe that this is the intention of the GDC.
Thank you Bad Robots for giving me the chance to coach this team.
Rookie All-Star Award: 2003 Buckeye
Engineering Inspiration Award: 2004 Pittsburgh, 2014 Crossroads
Chairman's Award: 2005 Pittsburgh, 2009 Buckeye, 2012 Queen City
Team Spirit Award: 2007 Buckeye, 2015 Queen City
Woodie Flowers Award: 2009 Buckeye
Dean's List Finalists: Phil Aufdencamp (2010), Lindsey Fox (2011), Kyle Torrico (2011), Alix Bernier (2013), Deepthi Thumuluri (2015)
Gracious Professionalism Award: 2013 Buckeye
Innovation in Controls Award: 2015 Pittsburgh
Event Finalists: 2012 CORI, 2016 Buckeye
