Go to Post FIRST already has 494 Martians, plus 70 more. - GaryVoshol [more]
Unread 08-02-2011, 13:15
cilginbilgin cilginbilgin is offline
FRC #2905
cilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the rough
Deleting Code Loaded on c-RIO
Hi,
When I deploy my code, and find a mistake on it I always correct the mistake and deploy it again but our c-RIO is getting filled and I should delete the codes which are not usuful.
I don't know how to delete them. Can someone help me with doing that process.
Thanks in advance!!!
Unread 08-02-2011, 13:44
Re: Deleting Code Loaded on c-RIO
When you "Run" a LabVIEW vi, or when you "Build" a project and then "Run as Startup", you automatically stop all user code already running on the cRIO. If you haven't made any uninstructed changes to the name of the compiled file, you automatically replace the previous program when you load a new one.
Unless you do something special to force them to stick around, old programs do not accumulate, so you do not need to clean them out.
