Go to Post it's shadows and fog and stormy skies and a reminder that things are rarely black and white but instead, the places in between. - MissInformation [more]
Unread 08-02-2011, 14:52
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: forklift system trouble!
Originally Posted by dduran View Post
how do you get the elevator to lock in place once it has reached its desired height? we are using a pulley system to make it rise, but dont know how to lock it in place to prevent back drive.
There are a few ways you could make it stay in place, Eagle33199 presented most of the commonly used and effective methods.
You can try adding some sort of passive assist to the lift (think counter balance) in an attempt to get it to hold position when un-powered. The easiest way I can think of doing this would be to make a few large bands from surgical tubing and have them stretched when the lift is fully compressed so that they're always pulling the lift open (up).
Originally Posted by jsasaki View Post
use your window motors and it wont back-drive
It'll also be slow...
-Dustin Benedict
Unread 08-02-2011, 14:56
jsasaki's Avatar
jsasaki jsasaki is offline
AKA: Jun Sasaki
jsasaki has a spectacular aura aboutjsasaki has a spectacular aura aboutjsasaki has a spectacular aura about
unlesssss you put a large drum on. we put two in parallel and works great for us.
Unread 08-02-2011, 15:16
Aren Siekmeier's Avatar
Aren Siekmeier Aren Siekmeier is online now
on walkabout
The large drum will speed it up, but greatly decrease the force effected in the end. In general, window motors simply don't have the power to do anything like that effectively (although if you can get it to work as well you need, great). We are going with 1 FP or 1 or 2 775s to get a quick lift in under 2 seconds (under 1 second, fingers crossed...).
