Go to Post Such reasonableness will not be tolerated! This is teh interwebz! - pfreivald [more]
Unread 07-02-2011, 18:00
Lakedaimon's Avatar
Lakedaimon Lakedaimon is offline
FRC #3012 (Spartans)
Lakedaimon is an unknown quantity at this point
cannot get fifth jaguar working
This is probably answered somewhere on the forum, but I couldn't find it.
We are using the DefaultRobot code, using four Jaguars to control four drive motors (using SpeedController). We are trying to add a fifth Jaguar to control a motor for our game piece manipulator.
In the DefaultRobot class we declare the fifth Jaguar as such -
Jaguar m_fifthMotor;
In teleopInit, we create the object with -
m_fifthMotor = new Jaguar(5);
Whenever this last line is not in, the four Jaguars for the drive system work fine. Whenever this last is compiled in, the four Jaguars blink while enabled, and thus do not work.
We don't see any errors on the debug output, and the cRio does not appear to be crashing.
What are we doing wrong?
Firmware is the most expensive thing in the universe. - Jack G. Ganssle
Unread 07-02-2011, 18:16
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
Post Re: cannot get fifth jaguar working
Dont know if this is your problem but last year we had trouble running more than 4 motors on a side car. The problem turned out to be an incomplete wiring connection(not enough contact with the wire). So check if all three Green LEDs are lit on the Digital Sidecar if not, redo the Wago connection with more wire contact to see if that solves your problem!
Hope that helps,
Jon
Expect the best, Prepare for the worst
Unread 08-02-2011, 17:55
Lakedaimon's Avatar
We had a wiring problem, the digital sidecar was not getting power from the distribution board. The 5v LED was the only LED lit, power was apparently leaking from somewhere else that was enough to run four motors, but not 5(?). Anyway, once the power was wired correctly, everything works fine. Thanks for the input!
Unread 11-02-2011, 22:36
drakesword drakesword is offline
AKA: Bryant
FRC #0346 (Robohawks)
drakesword is on a distinguished road
Do you have something else declared on the pwm port 5?
Is the code spitting out errors on the robot?
Do you see any error messages in the debug console?
Unread 14-02-2011, 19:03
ProgrammerMatt ProgrammerMatt is offline
Programmer-Electrical-Mechanical
FRC #0228 (Gus)
ProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really nice
How are you controlling these jags? CAN or PWM?
