Go to Post Johnny V-Neun. People just want to be his kind of cool... none of us really know why... - Pamela [more]
View Poll Results: Do you think this is impossible?
Yes 5 27.78%
No 13 72.22%
Voters: 18. You may not vote on this poll
Unread 08-02-2011, 17:58
BushTA's Avatar
BushTA BushTA is offline
AKA: Tom Bush
FRC #0173 (R.A.G.E.)
BushTA is an unknown quantity at this point
Send a message via AIM to BushTA
Re: Controling Pnumatics with joystick.
I've never done this, but have always wanted to try it out (like in the off season). You use a 3-position, Center closed, Solenoid Valve such as an SMC SY3340, with Flow Control elbow fittings to limit how fast the piston moves, and power the two valve coils from the outputs of a Spike (tie both coils negative leads to ground)[this also prevents the dreaded powering of both coils at the same time]. When the joystick is centered (null) have the Spike Off (no current to either coil) this will close both the extend and retract valve output ports, holding the piston still (mostly). When the joystick is pushed forward, power the solenoid that extends the piston. When the joystick is pulled backward power the solenoid that retracts the piston. I recommend that you use meter-out flow control elbows and put them on the valve manifold ouput ports. How well this holds a mid stroke position will depend on the load and probably whether the Driver was extending or retracting the piston prior to trying to stop it. It'll work better in the direction that is pressurizing the cylinder against the applied load.
Good Luck,
Unread 08-02-2011, 21:55
Team#2057-Vegas's Avatar
Team#2057-Vegas Team#2057-Vegas is offline
Team2057LasVegas
AKA: Justin Major
FRC #2057 (AV CyberBulls)
Team#2057-Vegas can only hope to improve
yes, it is possible, your joysticks + the speed controllers create the variables -1 through 1... you can either set your joystick variable 1 to true and set it so that if it isnt "1" then it is false or you can set forward to true and backwards to false. hope this helps (:
Justin Major
2057 Team Leader
"We will kick you off our pasture" -- 2057 Motto
Unread 09-02-2011, 01:00
bstrong1218's Avatar
bstrong1218 bstrong1218 is offline
Brandon
AKA: Brandon
FRC #3344 (Robocopz)
bstrong1218 is an unknown quantity at this point
Originally Posted by BushTA View Post
I've never done this, but have always wanted to try it out (like in the off season). You use a 3-position, Center closed, Solenoid Valve such as an SMC SY3340, with Flow Control elbow fittings to limit how fast the piston moves ...
We were looking at a similar approach until last week when another thread pointed out this ruling: http://forums.usfirst.org/showthread.php?t=16642
Our 3-position, center closed solenoid is in the mail, but we don't see a way to release all stored pressure when a single relief valve is opened, therefore making the setup illegal.
