Re: Minibot Fuse
A 20amp car fuse, go out to a car and look at it i believe they are normally yellow they are smaller than i dime. sorta triangle forks on the bottom
Re: Minibot Fuse
http://www.radioshack.com/product/in...ductId=2102773
One of those, a 20-amp mini-blade fuse as opposed to a standard blade fuse. |
Re: Minibot Fuse
Earlier update allows for low amp fuses down to 3 amps...helps protect your dc motors, especially while you are testing your prototypes.
