Go to Post Hall of Fame FIRST Team 254 has arguably helped more teams become good than any other team in FIRST. I don't think they need a lecture on helping their opponents. - Karthik [more]
Unread 07-02-2011, 23:25
NyCityKId's Avatar
NyCityKId NyCityKId is offline
That Weird Kid
AKA: Andre Dunkley
FRC #1601 (Quantum Samurai)
NyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to behold
Send a message via AIM to NyCityKId
1/8th thick aluminum
Hello all,
Team 1601 is having a small dilemma. We're trying to figure out whether we should switch our arm material to .032 thick 2024-T3 aluminum from .125 thick 6061-T6 aluminum. We are using two window motors on the same shaft geared 1:2 and with the 6061 aluminum our arm is going to weigh rougly 10 lbs. Would the change to the thinner aluminum be worth the loss in strength?
Unread 07-02-2011, 23:35
steelerborn's Avatar
steelerborn steelerborn is offline
Engineer at JBT FoodTech
AKA: Jonathan Stokes
FRC #5817 (Uni-Rex)
steelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant future
Re: 1/8th thick aluminum
I would say it really depends on how heavy your mechanism is on the end of the arm. Having a lot of weight dangling on the end, really increases the torque on the arm.
For instance we were using 1/8th inch aluminum sheet metal for our arm, after it was manufactured we noticed it was overkill. So we redesigned it to be 1/16th inch thickness. It decreased our arm weight by half, around 4-5 pounds total weight now. And by adding smart bends, and clever internal supports, our arm is just as sturdy.
Just test for your weak points and make a good solid design, if your using sheet metal remember that it gains strength with bends.
Hope this helps.
Good enough is the enemy of anything great!
team 1671
Unread 07-02-2011, 23:36
What size and shape tube are you using/proposing to use? A 1x1 will be a lot weaker than a 2" round tube.
Unread 07-02-2011, 23:43
What is your current projected robot weight? If you're looking at being under, you don't need to shed arm weight. If you're looking at being over, do the analysis. If you don't know how to do the analysis, say so--there are enough engineers on here that you'll get how to do the analysis and the analysis at the same time.
Unread 08-02-2011, 00:04
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Remember that comparing theoretical static stresses against material strengths won't be sufficient to guard against complicated load cases—like the ones you're likely to see in an arm that's in motion (i.e. has momentum) and may well be pushing or pulling on things (or being pushed or pulled itself).
The thicker material will be more resistant to deformation, because of the increased stiffness (the modulus of elasticity is roughly constant for all aluminum alloys), so you'll be less likely to suffer a dent that causes the member to buckle.
Also, depending on the details of the planned design, you may find it more convenient to lighten the arm by cutting strategically-placed holes, rather than making it from lighter stock.
We'll need lots more information to give you concrete suggestions about your particular design.
Unread 08-02-2011, 00:11
FRC #5817 (Uni-Rex)
Eric is right no point in making life more difficult, if you don't need to. Remember what is more beneficial redesigning an arm, or getting to practice for 3 more days?
team 1671
Unread 08-02-2011, 00:21
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Of course, you could change the question around to be, "What is more beneficial? Being lazy and not cutting down the weight on the arm and having it cut off at inspection or 3 days of drive practice?"
I would definitely run those calculations and cut it down if you have to.
Unread 08-02-2011, 01:09
Electrical Engineer
Rookie Year: 1995
Originally Posted by NyCityKId View Post
Hello all,
I'm not sure of the particulars of what or how your arm works but a ratio of 2:1 is pretty fast. Perhaps it is too fast to control? Changing gear ratios may be easier than building a new arm making it slower and having more torque all at the same time...
Mike Betts
As easy as 355/113...
Unread 08-02-2011, 01:25
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
we are using 1/8 aluminum for everything, some members have nearly 75% of the materiel cut out with our CNC in a triangular pocket pattern to keep it light. we probably wont do this with the end manipulator however because we are 6 LBS less than the CAD says it should be. the reason if that we dont want weakness on something that will likely be beat on other things a lot.
Unread 08-02-2011, 16:31
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
unless you have a very 80/20- and piston-heavy robot, it shouldn't be much of an issue with 1/8" aluminum. you can always swiss-cheese it later if need be
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 08-02-2011, 20:34
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
According to Machinery's handbook the yield stress for 6061-t6 is about 40ksi, ands 2024 is 57ksi, a 40% improvement. So it could be that you wind up with a stronger arm that is still lighter by changing alloys.
But to verify that I need the cross sectional dimensions of both the new material and the old.
I will say that .032 is pretty thin and easily dented. Those small dents can compromise the strength of the section. SO that is something to be considered as well.
The numbers on the trade off are pretty easy to run , but I need a few more of them
Christopher H Husmann, PE
"Who is John Galt?"
Unread 08-02-2011, 20:50
Chris is me's Avatar
AKA: Pinecone
I would go with 1/16" wall AL before you cut holes in 1/8" or go all the way down to 1/32".
This is assuming you have a relatively simple arm...
Unread 08-02-2011, 22:36
NyCityKId's Avatar
That Weird Kid
AKA: Andre Dunkley
We aren't using tubing for the arm.
It's not neccessarily an analysis that we need as far as weight goes, it's more a time analysis. We are trying to decide if changing the material and redesigning the arm will cost us more time that actually machining each piece by hand (we don't have a CNC machine, or any other fancyequipment). we wanted to know if any other team had a similar issue in the past and could possibly provide a little help. As of right now there isn't a weight problem.
From the very begining we designed the part to have triangular lightening holes to form a built-in truss like structure. The problem is 6061-T6 at 1/8th thick is not easy to machine by hand.
This is a point i brought up in our design sessions. I wanted to make it a 4:1 ratio for torque purposes and pointed out that ~40 rpm might be too fast for an arm that will be traveling ~180 degrees either way.
I'm sorry if the original post was not clear but we mainly want to know whether its worth it to go back and redesign at this point in time based on other teams past experience. Also consider that we don't have a CNC machine or a machine shop sponsor. I apologize for the unclear post and thank you all for your time.
Unread 08-02-2011, 22:40
NyCityKId's Avatar
That Weird Kid
AKA: Andre Dunkley
In the begining we all made a promise: that we would be proud of our robot and that there would be no wood. Swiss cheesing would definitely dent our pride
Unread 08-02-2011, 22:55
DonRotolo's Avatar
Back to humble
FRC #0832
Re-quoted for truth. Going from .125 all the way down to .032 is a big change. You may be satisfied with .062 (1/16"), as this cuts the weight in half. If you do change alloys, you gain 40% in yield strength, so it's a net loss of 30% of the original strength for 50% of the weight. Might be worth it.
