Go to Post As goes with all of my advice on CD, try it yourself and make up your own mind. I'm just suggesting things based on experience. See what works for your team. Follow my suggestions to the letter, mix and match them, or even throw them completely out the window. It's all about you and your team. - DampRobot [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 08-02-2011, 18:42
Matt Daioh's Avatar
Matt Daioh Matt Daioh is offline
FRC #3501 (Grinders)
Matt Daioh is an unknown quantity at this point
Circuit Breaker Placement
Hi everyone,
I am an electrician for our school's rookie team and I had a question.
According to rule <R37>, the circuit breaker need to be in an "quickly accessible" place, and we think that our current placement would work, but we thought it would be a good idea to check with people who are more experienced than we are.
Is this an acceptable place to put the breaker? If not, where would be a better place to put it?
Thank you all!
Unread 08-02-2011, 21:17
Colin P's Avatar
Colin P Colin P is offline
MTU Robotic Systems Enterprise
AKA: Colin Putters
FRC #0857 (Da Yooper Troopers 3771, Unbolted Puppeteers 4363)
Colin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to behold
Re: Circuit Breaker Placement
I'd recommend moving it to the side of what the jags are mounted on. Like the radio, but on the other side.
Outside of the rules, it's best for everyone to have that as easily accesible as possible. Monkeying around inside the robot to turn it on is never fun, and can bump PWMs and whatnot out of place.
Unread 08-02-2011, 21:24
Aren Siekmeier's Avatar
on walkabout
Not to mention turning it off, especially in case of an accident!
Unread 08-02-2011, 22:47
DonRotolo's Avatar
Back to humble
FRC #0832
Imagine this scenario: Your robot is on the field, and it is smoking heavily (nearly on fire). Someone who has never seen your robot needs to turn off the main breaker. NOW.
Now, ask yourself: Is that breaker accessible/visible?
Use that standard, and you'll be fine.
As for the position now, I don't like it, too far inside the robot.
