Go to Post One of these years, the game piece will be an actual red herring. - Taylor [more]
Unread 08-02-2011, 19:15
Ian McShane Ian McShane is offline
FRC #3585 (Rogue Robots)
Ian McShane will become famous soon enoughIan McShane will become famous soon enough
Where do i find the set speed vi?
cant seem so find it.
Unread 08-02-2011, 19:22
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Re: Where do i find the set speed vi?
Have you tried using the Search feature in Labview to find it? It will be located somewhere in the WPI libraries in the toolbox. Also be sure you are on the Block Diagram rather than the Front Panel. Also make sure you have installed all the latest Labview updates.
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 08-02-2011, 19:25
have all updates, could only find the jaguar set speed in the search, needs to be the yellow block for the motor.
Unread 08-02-2011, 21:28
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
What are you trying to use the setspeed.vi for? It will work for both Victors and Jags
Expect the best, Prepare for the worst
Unread 09-02-2011, 00:36
Set speed in the previous years was a misnomer, and was renamed this year to set output. It sounds like the tutorial you are using is out of date.
Unread 12-02-2011, 11:21
Slothbron's Avatar
Slothbron Slothbron is offline
AKA: Nathan
FRC #3216 (Missoula Robotics Team)
Slothbron is an unknown quantity at this point
Yes use a set output it works just like the set speed vi.
MRT 3216
2010- Salt lake City Highest Rookie Team seed
