Go to Post [Pi day] is an irrational holiday - KenWittlief [more]
Unread 08-02-2011, 17:48
siggy2xc siggy2xc is offline
AKA: Tyler Siegrist
FRC #1756 (Argos)
siggy2xc is an unknown quantity at this point
3 outputs for 2 booleans
I have 2 booleans and would like to be able to use 4 different case structures depending on which are pressed.
False, False
True, False
False, True
True, True
What would be the best way to do this?
Unread 08-02-2011, 17:57
Wicked Wicked is offline
FRC #0354 (G-House Pirates)
Wicked is an unknown quantity at this point
Re: 3 outputs for 2 booleans
You might be able to use some combination of the Boolean functions in the palette to do this.
Unread 08-02-2011, 21:34
Just nest one Case statement within another one.
Unread 08-02-2011, 23:31
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
Thats the hard to understand way. The easy way to do it is to build an array (Build Array) and then put that array into a number (Boolean Array to Number) then put that number into a case structure (that will change the true/false selector to a 0, Default/1 selector). Now it helps to know binary at this point. You right click the selector and add a case after. Do this until you have 4 cases (0, Default; 1; 2; and 3). If both booleans are off the case is 0 (false, false). If boolean 1 is on and 2 is off the case is 1 (true, false). If boolean 2 is on and 1 is off the case is 2 (false, true). If both are on the case is 3 (true, true). See the attached picture for wiring.
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
Unread 09-02-2011, 00:26
AKA: Tyler Siegrist
FRC #1756 (Argos)
Thanks j.cole! saves me a lot of time
