Go to Post From a coaching standpoint, I can tell you...the coach is NOTHING without valuable scout information. If the coach is nothing, the robot is NOTHING. It all starts from the scouts...get your kids to see this. - Brandon Holley [more]
Unread 08-02-2011, 22:56
Garten Haeska's Avatar
Garten Haeska Garten Haeska is offline
AKA: Garty
FRC #2861 (Infinity's End)
Garten Haeska has a spectacular aura aboutGarten Haeska has a spectacular aura about
custom operator console
Hello,
my team was looking into making a custom operator console consisting of a laptop computer connected to a 21in. monitor so the screen is bigger and we would be powering this by some of our practice batteries using the andymark converter. Would this be legal as long as it all fits in our own little rectangle?
Unread 09-02-2011, 02:33
Cow Bell Solo's Avatar
Cow Bell Solo Cow Bell Solo is offline
No Stolte No
AKA: Chris
FRC #2194 (Fondy Fire)
Cow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the rough
Send a message via AIM to Cow Bell Solo Send a message via MSN to Cow Bell Solo Send a message via Yahoo to Cow Bell Solo
Re: custom operator console
Like with anything else when thinking about the rules and whether something is legal or not check the Manual. I know it is emphasized plenty of times on here but all the answer can be found in the Manual.
For example In the Robot section there is a whole section labeled Operator Console and the rules and regulations associated with it. That would be section 4.3.12. I would check with your plans and see if anything conflicts with those rules
There is also information about the Play Stations in The Arena section 2.2.8
I would check with those parts and just double check through the rest of the manual to make sure. But if stuff doesn't break the rules they have stated I is most likely legal and you should be fine.
Your next consideration I would suggest with a 21in monitor is, is it practical. Are you going to be able to see around it to see the field? Do you need it THAT big? How are you going to carry/bring it out there while you are in queue? Will it be quick to setup and then tear down as we all know they don't like to waste time? Or anything else along those lines.
Hope this helps.
Who let the Blue Smoke Out
Team 2194 Mentor - 2012-Present - http://fondyfire.com
Team 2207 Alumni - http://whitebearlakerobotics.com
Iowa FIRST LEGO League Planning Team Member - 2010-Present - http://www.isek.iastate.edu/fll
FIRST LEGO League volunteer - 2008-Present
2008: MN Regional Quarterfinalists, Website Excellence
2009: MN North Star Quarterfinalists, recognized for safety, Website Excellence
Unread 10-02-2011, 19:35
AKA: Garty
the plan is to have it so that everything is bolted down is such a way that it doesnt fall off. It will all just fit on our custom cart with our robot and everything on the console with be secure enough to the point that it wont fall off. The reason we want to use a 21in. monitor is because that way we can use an app. that allow us to send our camera image from our dashboard to the monitor so the monitor only displays the camera image.
