Go to Post BTW don't trust game hint threads started by Greg Needel. - rtfgnow [more]
Unread 08-02-2011, 23:16
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Optical Encoders Help!!!!!!!!!!!!!
You are actually limited to 12 in hardware. Why? The FPGA can only handle 8 Counters and 4 Encoders. the Encoder library uses Encoders for 4x decoding (meaning you can use up to (4) 4x-decoded encoders) and Counters for 1x or 2x decoding (meaning you can have up to (8) 1x or 2x-decoded encoders). 4+8=12, so 12 encoders max.
This assumes that each encoder is either quadrature or otherwise uses the FPGA Counters (such as a gear tooth sensor).
If you need more than 12, your best bet would probably be to use a co-processor to handle the inputs and either feed them to the cRio via SPI, I2C, Serial, or DACs.
Kettering Motorsports
