Go to Post Don't bring a distraction to the field. - Al Skierkiewicz [more]
Unread 08-02-2011, 00:18
Blazanax's Avatar
Blazanax Blazanax is offline
FRC #2443
Blazanax is an unknown quantity at this point
Optical Encoders Help!!!!!!!!!!!!!
How many optical encoders are we allowed to use on the robot this year?
Unread 08-02-2011, 08:23
Chexposito's Avatar
Chexposito Chexposito is offline
AKA: Expo
FRC #1730
Chexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of light
Re: Optical Encoders Help!!!!!!!!!!!!!
Well, it depends, i believe it is limitless. The only snag you may have is the number of C-Rio Cards you have and sidecars you have. Other than that i believe those are the only limits... we have left over digital inputs on our sidecar and on the C-Rio itself... We're using 4 encoders, the linetrackers, an optical sensor, and the compressor... how many do you plan to use?
Unread 08-02-2011, 22:03
Blazanax's Avatar
FRC #2443
Do you mean how many encoders are we using or compressors?
Unread 08-02-2011, 23:05
Chexposito's Avatar
AKA: Expo
FRC #1730
how many encoders you want to use
Unread 08-02-2011, 23:16
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
You are actually limited to 12 in hardware. Why? The FPGA can only handle 8 Counters and 4 Encoders. the Encoder library uses Encoders for 4x decoding (meaning you can use up to (4) 4x-decoded encoders) and Counters for 1x or 2x decoding (meaning you can have up to (8) 1x or 2x-decoded encoders). 4+8=12, so 12 encoders max.
This assumes that each encoder is either quadrature or otherwise uses the FPGA Counters (such as a gear tooth sensor).
If you need more than 12, your best bet would probably be to use a co-processor to handle the inputs and either feed them to the cRio via SPI, I2C, Serial, or DACs.
Kettering Motorsports
Unread 09-02-2011, 00:59
You're limited to 41 jaguars by cost, but each jaguar can read a single encoder using CAN.
