Go to Post What’s in a name? That which we call a robot, by any other word would smell of magic smoke. - Jack Jones [more]
Unread 09-02-2011, 00:41
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Minibot can we use Delrin or acetal?
For our minibot we are wanting to use Delrin or acetal, and according to the game documentation we are allowed to use Polycarbonate.
Does any one know if this is legal?
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 09-02-2011, 01:06
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Re: Minibot can we use Delrin or acetal?
Both materials are not included in the list found in R92, therefore are not legal materials.
Unread 09-02-2011, 01:21
Mk.32's Avatar
AKA: Mark
well they are both thermoplastic polymers maybe stretch it a bit hehe
Unread 09-02-2011, 01:30
Originally Posted by Mk.32 View Post
well they are both thermoplastic polymers maybe search it a bit hehe
But if they aren't on the list, they aren't on the list. Polycarb is on the list. Delrin and acetal are not.
If you show up to inspection, and the inspectors ask what material that is, and you can't show that it's on the list, guess who'll be fixing their minibot? I know inspectors who can tell Delrin from Lexan very easily; I'd guess that acetal would also be fairly easy (I don't really have any experience with it).
Also, see PVC pipe versus PVC sheet. One is legal. One is not. Same material, different legality.
Unread 09-02-2011, 03:02
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
It's basically a matter of seeing how it reacts to a fingernail. Polycarbonate (Lexan, for example) scratches lightly, and feels hard without any waxiness, so consequently has somewhat high friction; it's also quite flexible. Polyethylene will take a bit of an indentation, and feels waxy (the density is proportional to the molecular weight, so you can tell something about the grade too). Polyoxymethylene (which is the same as polyacetal, and which is sold under the trade name Delrin) is slick, but quite hard and stiff. Polytetrafluoroethylene (Teflon) is very slick, but also soft and flexible.
You can sometimes tell a bit about the composition by the colour, but this can be dyed and therefore misleading. Virgin PC is usually clear, while the others are usually whitish (PE and PTFE) or off-white (POM).
Fibre-filled plastics complicate this somewhat, but you can usually observe the surface and tell if there are fibres inside (usually made of glass). That makes it stiffer and harder, on average.
Of course there are other less-common plastics too (polystyrene, acrylonitrile butadiene styrene, etc.), or blends (like in injection moulded items) that are hard to identify. But most of those aren't common in robots because they're weak, unavailable or otherwise objectionable.
Unread 09-02-2011, 08:01
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Delrin is a brand name for acetal polyoxymethylene (POM). More commonly called acetal co-polymer. So they are the same thing.
Former Mentor Team 1771
Former mentor Team 4509
Unread 09-02-2011, 08:15
In checking for polycarbonate brand names, I found these...
TRISTAR®, LEXAN®, CALIBRE®, MAKROLON®, Barlo® there are others mostly used in specialty forms like grids and membranes. Delrin is classed separately and is often compared with polycarb for it's distinctly different properties. Polycarbonate is the only allowed material on the list.
