Go to Post Antimatter.. It will help us in the never ending quest to build the bot under the weight limit. - Elgin Clock [more]
Unread 09-02-2011, 06:50
Re: C-rio old vs new
Post a picture. If pins are bent, you probably want it fixed. If there are holes drilled in it or other mods, it won't pass inspection at an event. The RMA process is quite fast, but this is typically for units that aren't functioning.
Greg McKaskle
