Go to Post Two students with no clue but enough dedication to work on something is always better than one expert who doesn't care enough not to leaveit until the last day. - Matt Krass [more]
Go Back   Chief Delphi > Competition > OCCRA
Unread 03-11-2002, 22:34
Dstiebel Dstiebel is offline
#0180 (Jag-Wires)
Dstiebel is an unknown quantity at this point
Question unusual parts
My team needs a counterweight for our arm. We want to use a trailer hitch ball, but is that allowed? WHat about a small barbell?
Unread 04-11-2002, 02:28
Mr. Mac Mr. Mac is offline
#0001 (Juggernauts)
Mr. Mac is on a distinguished road
Look At the Additional Materials List
Neither item you mentioned are in the kit or on the additional materials list, so they are not allowed. Springs and surgical (latex) tubing are on the list and could be used to supply a counterforce. I suppose a stack of 3/8" rod stock pieces (nicely duct taped together!) would accomplish the same thing. The important thing is to stick to the list.
Unread 04-11-2002, 16:21
#0180 (Jag-Wires)
extra battery?
how about using a second battery as a counterweight? It would not be used to power anything, just as a counterweight. The materials list isnt clear on this however i think i remember someone mentioning it last year.
Unread 04-11-2002, 19:53
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
Extra battery
This is not allowed. The implication would be that you have wired two batteries for extra juice.
If you need additional weight, use any material found on the additional materials list or in the kit of parts. Consider the density when choosing.
Look close there are many good choices. Styrofoam would not be a good choice.
Mike Martus
Unread 05-11-2002, 00:30
#0001 (Juggernauts)
Use Styrofoam as a Counterweight?
Martus is right: You should definitely not use styrofoam as a counterweight, unless of course, you were having trouble making weight.
Unread 05-11-2002, 12:53
Jack's Avatar
Jack Jack is offline
FIRST Scouting Network
AKA: Andrew Schenk
FRC #0201 (The FEDS)
Jack is a jewel in the roughJack is a jewel in the roughJack is a jewel in the rough
Send a message via AIM to Jack
Um.. even if you have trouble making weight, you still couldn't use styrofoam becasue a counterweight is not the size, but mass. For a counterweight, you need something heavy and dense, like metal.
Why does it seem that normally the bots need to go on a diet, but this year they can eat a feast?
Team 201 - 2003 Great Lakes Semifinalists & 2003 Archimedes Division Finalists :|: Webmaster of www.feds201.com -> FBI Scouting
Winner of The 2003 ChiefDelphi Web Award for: User That Started The Most Non Chit Chat Threads
Winner of: 2003 FIRST Ventures with 5451.68 End Points
All about me: http://knehcsa.vze.com
**Check out the New FIRST Scouting Network**
Unread 05-11-2002, 23:21
#0001 (Juggernauts)
Better than styrofoam:
Martus and I were joking about the styrofoam counterweights, of course, but there is another light thing you could counterforce with: a vacuum. Put your little cylinder close to the pivot, set the arm to the height you like, then seal the two ports of the cylinder. It will apply significant force trying to return to that original position, so your motors will not have to exert as much force. I have never actually tried this, but it seems like it should work.
Unread 06-11-2002, 15:05
f22flyboy's Avatar
f22flyboy f22flyboy is offline
Distributor of Mayhem
#0540 (Rhythmic Disturbance)
f22flyboy will become famous soon enoughf22flyboy will become famous soon enough
latex tubing
Latex tubing would be a much better option than a counter-weight, unless by some miracle you are not even close to 130lbs
Godwin Robotics Association- Rhythmic Disturbance
Team 540 Forums
FIRST Look... FIRST Shot... FIRST Kill.
Unread 07-11-2002, 08:35
Jim Meyer's Avatar
Jim Meyer Jim Meyer is offline
Engineering Mentor
None #0067 (HOT)
Jim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond repute
I believe springs are also on the additional hardware list. Our team used them effectively on last year's OCCRA machine. Ours were about 1.5" in diameter and approximately 4" long and we used 3 of them.
As a side note for future competitions, it would be good to have a material on the additional hardware list that made for good ballast. Anything steel or even some dumbell weights.
Unread 09-11-2002, 09:10
Springs
Yes springs are on the additional materials list. They must be "off the shelf" NOT custom made or fabricated.
Mike Martus
Unread 09-11-2002, 22:38
Jack's Avatar
AKA: Andrew Schenk
Re: Springs
How about 'gas springs' They are the things on the doors that make a 'hisss' sound when closing. they also are used on the glass backs in cars and would be avaible in an auto store. I can't remember which one we could go to, but i know we could go to at least one. If we bought them right off the shelf, would they be legal? (They are a spring)
Thanks
Unread 09-11-2002, 23:38
Gas springs
This has been covered before. same answer. They are not what we consider the common definition of a spring. They fall more in line of Gas Struts - and they are not on the additional materials list.
While they may give the same results, they are not what we think of when we say spring.
Mike Martus
Rules on making spare parts fyi DougHogg General Forum 0 02-04-2003 16:18
Calling all Lawyers... ...Define "all parts" Joe Johnson General Forum 10 13-03-2002 15:12
pole flexing, buying parts gthakore Rules/Strategy 1 21-01-2002 12:02
What advice would you give? Jessica Boucher General Forum 8 02-12-2001 07:10
Substitute Parts BHSFirst Off-Season Events 1 08-11-2001 19:23
