Go to Post Teams rarely win FIRST events because they can complete actions that nobody else can; they win because they do things faster than others. - Madison [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 08-02-2011, 12:22
Re: Why are Limit Switches outlawed with PWM, but not CAN?
Phil,
The limit switch rule was in place in 2009 not CAN bus use.
From 2009 Inspection Checklist
Custom Circuits, Sensors and Additional Electronics - cannot be attached to the cRIO’s serial port or Ethernet port 2 (except for the Axis 206 camera), cannot attach to Jaguar CAN or limit switch ports,...
Unread 08-02-2011, 13:07
Phil,
No wonder we're confused by what you're saying. That's not the rule we're talking about here. This year's <R55> J does permit limit switches when using CAN control.
Unread 08-02-2011, 13:09
I thought that Phil was asking about limit switches when using the PWM inputs in his first post.
Unread 08-02-2011, 16:28
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Allow me to restate my question now that we have a few more facts.
(I am having our team leader post this on the Q&A... but just let me clarify)
We've established that regardless of the control method you are using with the Jaguars (CAN or PWM), the Limit switch inputs perform the same control function... that is: they stop the motor running a specific direction if that limit switch circuit goes open-circuit.
This in no way compromises any safety/watchdog/loss-of-comms/FCS shutdown action. It actually adds a level of safety.
The only difference between the two interfaces is that CAN ALSO lets the cRIO read the state of the switches, in case it wants to take some other action (since the motor is already shut down)
So my question is: Why can we connect limit switches to the Jaguar if we are using CAN bus, but not if we are using PWM. The automatic limit control action is the same. Please let us use it!!!
Just because CAN can read the inputs, there is no requirment to do so, but having the automated limit switch is a COOL feature to provide a faster response AND it frees up DSC I/Os for other uses (my other reason for wanting this).
Phil.
Phil Malone
http://www.GEARSinc.org
Unread 08-02-2011, 22:42
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
I currently see no downside - safety or otherwise - in allowing direct limit switch use with the Jaguars in PWM mode. Particularly if they've already been allowed in CAN mode.
Is there something we're missing here?
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 09-02-2011, 02:46
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
I'm guessing it's similar reasoning that almost outlawed closed-loop control on the Jaguar entirely. It's not founded in anything technical or safety related.
-Joe
Unread 09-02-2011, 07:49
Phil,
I am not a programmer so tender my answer with that. It is my understanding (from inspector training) that in the CAN implementation, the state of the limit must be read, passed on the CAN bus to the Crio which then generates motor command. Under FMS the Crio is controlled and the limit switch based commands are then enabled or inhibited by the FMS command. It is for this (and others) reason that we went through several firmware revisions in that first year. As each revision was released, it was necessary to determine that any and all motion could be stopped by the FMS. If it could not, then another release was generated. The safety of the participants, volunteers and field are still the highest priority in making decisions about the control system.
Please ask the Q&A so everyone can be satisfied.
Unread 09-02-2011, 08:12
I'm pretty sure your understanding is faulty. From everything I have seen in action and read in the available documentation, the limit switch action is entirely independent of any commands to the Jaguar, either by CAN or PWM, whether FMS is involved or not.
Unread 09-02-2011, 09:39
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
Phil,
The limit switch functionality is independent of commands; there is no way to override the limit switches in software.
There is a "Soft Limit" feature that uses the encoder or potentiometer to read the position, and stops the motors at a user defined position. However, motor movement will still be stopped by the hardware limit switch opening the circuit, even if it hasn't reached the soft limit yet.
When using CAN, it is entirely up to the user to read the limit switch states from the Jaguar. The cRIO does not issue motor commands based on the limit switch states. The cRIO issues standard commands and the Jaguar follows them to the best of its ability. If the cRIO is telling the Jaguar "move forward!" it will try to. If, however, the forward limit switch input is open-circuit, the Jaguar will not move forward, despite the cRIO continuing to send a forward command.
The multiple Jaguar firmware updates last year were to fix bugs (a power-up bug, PID bugs, etc.), none of which had to do with the limit switches or the FMS. Actually, the FMS doesn't ever talk to a Jaguar; it tells the cRIO "Disable!", the cRIO stops sending motor commands, and the Jaguar times out.
-David
Unread 09-02-2011, 10:01
PhilBot's Avatar
AKA: Phil Malone
Phil,
I have posted the question.
Whether everyone will be satisfied is a completely different issue
If nothing else, it will be interesting to hear the reasoning behind this rule.
Phil.
Phil Malone
Unread 09-02-2011, 14:20
David,
I was speaking of the updates in 2009 when this control system was first introduced.
Unread 09-02-2011, 15:53
David,
There were no jaguar firmware updates in 2009 because no team had the capability of loading them.
Unread 09-02-2011, 17:55
OK,
There were Crio, driver's station and Lab View updates in 2009, parts of which addressed the inability to turn off Jaguars reliably at the end of a match. Not only was it not possible to update the Jaguar, there was no way to check it since CAN was not legal in 2009 nor was it legal to connect to the CAN bus connector on the Jaguar.
