Go to Post Brandon, can you make some sort of mind-reading device that i can just think "portal" and i'll go back? - Tom Schindler [more]
Unread 09-02-2011, 09:14
DFZXA DFZXA is offline
FRC #3055 (Furious George)
DFZXA is infamous around these parts
Stop button malfunction
Our first laptop is not detecting our stop button. It keeps saying that device has malfunctioned. It is still lighting up. Is there a driver for it somewhere because I cannot find it?
Unread 09-02-2011, 09:20
pfreivald's Avatar
AKA: Patrick Freivald
Re: Stop button malfunction
When this happened to us last year, we had to replace it.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 09-02-2011, 09:22
It presents itself as a standard USB keyboard. There is no special driver.
Unread 09-02-2011, 09:38
Oh well thanks then do you know any reason for why this happened? Someone on my team was playing with it the other day.
Unread 09-02-2011, 11:51
Brian Ha's Avatar
Brian Ha Brian Ha is offline
Teh Ha Kid
FRC #0302 (Team 302)
Team Role: Driver
Brian Ha has a spectacular aura aboutBrian Ha has a spectacular aura aboutBrian Ha has a spectacular aura about
Basically the cord plugged to the stop button has been messed up. If you want to use the driver station before your new stop button comes in there is a bypass. I can't remember for sure because it is not in front of me at the moment but go to the second tab on the driver station, then go down to the stop button, the light should be off, double click on it, a pop up should come up asking if you meant to disable the stop button, continue to click on the one that says I'll be careful, there should be a countdown, don't be alarmed it's not blowing up it just needs twenty seconds to disable the stop button. If you do do this have someone by the disable button so if you haven't tried the program yet you won't all die. Tell me if it works, good luck.
Starcraft 2 Hit me up Cheese 972, or join the FRC chat room ingame
Unread 09-02-2011, 19:56
Yep that works I was just more worried about having a working one for competition. Luckily we have another one, so we are fine. Thanks for the help everyone
Unread 09-02-2011, 22:14
You won't be using a stop button at competition events. The emergency stop function is provided by the field electronics.
Unread 10-02-2011, 08:35
2bkrul's Avatar
2bkrul 2bkrul is offline
Whats tht burnin smell..oh the Jag!
AKA: Brandon Krul
FRC #0964 (Bedford Robotics)
2bkrul is an unknown quantity at this point
I thought we had to have one at the Operators Counsel just in case something went wrong?
"Building robots is a lot better with doughnuts around"
-Team 964 2010 Team Motto
Team 964 on TBA!
The Home of Bedford Robotics!
Unread 10-02-2011, 09:09
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
As Alan said, you will not use your USB Stop button on the field at your competition. There is an Emergency Stop button provided in each Driver Station on the field and the Emergency Stop functionality will be handled by the Field Control System.
