Go to Post As an adult who has spent years working with youth in Boy Scouts and FIRST, and on behalf of all other adults at the event: deodorant. - Rick TYler [more]
Unread 09-02-2011, 12:11
Trump Trump is offline
FRC #2053
Trump is an unknown quantity at this point
Re: WPILib Mecanum Function Not Strafing Properly
Are the rollers on your wheels making an X or an O from the top. The need to make an X from the top (O form the bottom).
Two of your motors should be inverted (in code, or by switching the pos and ground). This is because the motors on one side will spin in the oposite direction on one side of the bot when they are given the same signal.
Are you Using C++, Java, or LabView?
Unread 10-02-2011, 21:04
CodeMonkeyMatt CodeMonkeyMatt is offline
FRC #2605
CodeMonkeyMatt is on a distinguished road
They are making the X on top.
I'm pretty sure they're properly inverted because forward and rotation worked, just not strafe. I figure that since we'd be using the RobotDrive class (I thought it went without saying due to the forum I'm in, we're using C++) it was naturally set up for the inverted motors and did it automatically.
Unread 10-02-2011, 23:07
If you had control of the front motor on one side swapped with the rear motor on that side, you'd probably get the results you're seeing. Start by verifying that the motors you're telling the code about are actually on the corners you're telling it they're on.
Unread 12-02-2011, 02:48
FRC #2605
That sounds promising now that you mention it. Unfortunately, I'm not working on the robot for a bit, so I'll have to look into that and get back to you guys in a couple days.
