Minibot (Tetrix) Questions
A few questions about the minibot, created with mostly tetrix parts...
1. The "mini-kit" we're using at the moment doesn't have much in terms of controllability. It seems that we have two motors, one on-off switch, a battery, and nothing else. How are teams controlling these things? 2. Even though plexiglass isn't polycarbonate, it's not allowed as a substitute, I assume 3. Are springs allowed on the minibot? The rules don't say anything about them, but we -are- allowed to use rubber bands and surgical tubing. 4. Are we allowed to use any other electronic components, such as resistors and relays? Thanks for the help Last edited by BrandonQ : 09-02-2011 at 15:54. |
Re: Minibot (Tetrix) Questions
Springs are not allowed on the Minibot, because anything not specifically permitted is prohibited (first line of <R92>). |
Ah, we wanted to use the springs for a small gripper, but now I see that they're not allowed (Replace with surgical tubing, maybe)
Also, since limit switches are allowed, are there "permanent" limit switches (That remain off after they flip off, for when the robot hits the top)? As far as I know (Which isn't much), they are only temporary. Last edited by BrandonQ : 09-02-2011 at 16:48. |
You are allowed to use up to two household light switches in addition to limit switches.
One more question...
For speed, what would the best gear ratio for an indirect drive? |
#7
#8
It depends on wheel diameter and whether or not you left the gearhead on or not.
#9
Can we change the battery out I found a 12v 3000mah NIMH battery that is lighter weight
#10
you must use the kit battery or an identical tetrix battery. no exceptions. please read the manual. it has the answer to your question directly stated. Last edited by ratdude747 : 09-02-2011 at 19:56. |
#11
Question: does anyone know if any DPDT "household light" switches exist, and if they can be used? Or do they all have to be the "standard" SPDT? (I know that we can also just attach two SPDT's together)
#12
Brandon,
I have seen them but they are not generally on the shelf since the demand is so low. |
#13
If it's a light switch meant to be installed in a household wiring box, it's fine. (This could lead to some interesting designs using non-North-American switch types.) |
#14
On the topic of house switches does anybody know if we can disassemble the switch. As far as I know that is still allowed but I just want to make sure. also if someone could tell em how to find a Q & A forum or something of the sort so I can direct my questions there next time. Thanks.
#15
They should be in any decent hardware store but you'll need to look for one marked "4-way" switch. They are specifically noted in the current manual revision so yes they are legal.
