Go to Post The game is going to be exciting. I want a front row seat and a big box of buttered popcorn. - JaneYoung [more]
Unread 09-02-2011, 16:42
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
Re: Possible bad Jaguar.... Thoughts?
Originally Posted by PhilBot View Post
I don't suppose the current limit is configurable (and mine got set too low).
The current limit is not configurable, but the fault shut-off time is. You can set the fault shutoff time as low as 500 ms.
I am not familiar with the proper WPI Library calls to set this parameter, maybe someone else can comment.
The fault is occuring well before 2 seconds elapses.
The over current protection uses a timer to count how long the Jaguar is operating above the limit. This timer follows an exponential equation that intersects at 60A and 2 seconds. Above 60A the Jaguar will shut off at exponentially smaller time periods. For >100A the time until shutoff is quite short.
-David
Unread 15-02-2011, 18:52
lucoytoa's Avatar
lucoytoa lucoytoa is offline
Programmer
AKA: Nicolas Xiong
FRC #2276 (STARS of Cypress)
lucoytoa is an unknown quantity at this point
-David
We're experiencing this same problem. Where in Labview can we change this?
FRC - STARS of Cypress, 2008, 2009, 2010
FTC - SOAR Club - 2011
FLL - DNAbots - 2009, 2010
BEST - STARS of Cypress - 2008, 2009, 2010
MATE - STARS of Cypress - 2008
MATE - SOAR Club - 2011
VEX - Discobots - 2010
Robofest - 2008
Houston: Energy City of the Future - RNKL Engineering - 2009
Unread 15-02-2011, 20:39
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
This is a CAN-only feature.
You can adjust it with the "config fault time" function in Actuators > Motors > CAN.
-- Marshal Horn
Unread 23-02-2011, 12:30
hydrocannon hydrocannon is offline
FRC #3778 (Texsquad)
hydrocannon is an unknown quantity at this point
bad jaguars we lost three out of four in the last few days and last night we realized the crio was recieving twice has much power has it suposed too could are jaguars been because they were recieving to much power?
Unread 23-02-2011, 15:47
hydro,
There is no way for you to supply twice as much power to the Crio. It should be connected to the +24 volt output connector on the PD. This is the highest voltage on the robot. Everything else is either 12 volts or below. The Jaguars receive no power from the Crio.
