Go to Post Wow, an entire thread with positive comments. I must be on the wrong forum... but my URL still says chiefdelphi.com. Hmmmm... - Chris Hibner [more]
Unread 09-02-2011, 16:41
Jared Russell's Avatar
Taking a year (mostly) off
Automatically log out when quitting Driver Station app
(While logged in under the "Driver" account).
Is there any way to change this behavior?
Unread 09-02-2011, 17:03
Re: Automatically log out when quitting Driver Station app
The driver station software is actually running as the shell, rather then explorer.exe. If you could exit the driver station software without logging out, all you'd have is a black screen. There is a registry setting that controls this behavior that someone posted previously, but I can't find it.
Unread 09-02-2011, 17:20
Even when I launch it from the start menu? I have a non-Classmate netbook that I'm using under a "Driver" account.
Unread 09-02-2011, 17:44
No, sorry, that only applies on the classmate.
Unread 09-02-2011, 20:52
The exit code calls shutdown -l whenever it is the driver account. That is a hold-over from the classmate only install, and should probably be configurable. If you configure the DS to run as shell, the current setting will make more sense. Meanwhile, I'll add it as a fix/improvement for FIRST to consider for next year.
Greg McKaskle
Unread 09-02-2011, 21:27
Gotcha. It isn't the end of the world having to press "Cancel" when the logoff prompt comes up, but it would be nice to be able to configure the behavior.
Unread 13-02-2011, 14:43
Todd's Avatar
Todd Todd is offline
Software Engineer
FRC #1071 (Team Max)
Todd is just really niceTodd is just really niceTodd is just really niceTodd is just really niceTodd is just really nice
Instructions on changing the shell for those that end up here looking for it:
http://www.chiefdelphi.com/forums/sh...ad.php?t=89340
