Go to Post The bulk of the hardest fun you'll ever have is opening up that box in early january, and the six week of chaos that that box of parts puts you through. - Joe G. [more]
Unread 09-02-2011, 17:21
Biolore Biolore is offline
Lead Programmer
AKA: Josh
FRC #3597 (Robo-Rangers)
Biolore is infamous around these partsBiolore is infamous around these parts
Old Motors
So, my team has a motor from a 2007 robot that was donated to us that we are planning on using for our deployment system, though its a little unclear if we can use it.
Unread 09-02-2011, 17:26
Lead Programmer
AKA: Josh
Re: Old Motors
https://doc-0c-60-docs.googleusercon...0 upr9i9o9htg
Unread 09-02-2011, 17:31
Re: Old Motors
Stop. If it's unclear that you can use it, read the Manual. Particularly read <R46> and <R45>.
If that motor is the same as a motor from the 2011 KOP, and is within the allowed quantities, then it is legal. If it is not, do not use it on the shelf.
Unread 09-02-2011, 17:36
Lead Programmer
AKA: Josh
Re: Old Motors
It's still unclear. I've tried posting a picture twice, and so far, it's not working
Unread 09-02-2011, 17:43
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Re: Old Motors
Quickly describe it with dimensions?
Unread 09-02-2011, 17:47
Lead Programmer
AKA: Josh
Re: Old Motors
it's similar to the car window motors, but larger. The motor itself is 4" long and 2" wide, mounted to a gear thing that is about 3"x3," though it's not square and maybe an inch thick
Unread 09-02-2011, 17:50
Lead Programmer
AKA: Josh
Re: Old Motors
It is also solid metal
Unread 09-02-2011, 17:51
Matt C's Avatar
FRC #1468 (J-Birds)
Re: Old Motors
Does it have a long metal shaft? If so it's probably a van door motor.
(This would also mean it's not allowed in this year's competition)
Unread 09-02-2011, 17:52
big1boom big1boom is offline
Chains=Fun
FRC #2022 (Titan Robotics)
big1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of light
Re: Old Motors
sounds like one of the old Keyang motors
2007 KOP checklist
http://www.usfirst.org/uploadedFiles...klist_RevE.pdf
page 3?
If it is, then it is illegal. Just use one of the Denso Window motors from this years kit.
Unread 09-02-2011, 17:54
Matt C's Avatar
FRC #1468 (J-Birds)
Re: Old Motors
Actually yes, it is probably a Keyang as the van door motors went away prior to 2007.
Unread 09-02-2011, 17:57
Lead Programmer
AKA: Josh
Re: Old Motors
It is that motor. We were using that because it had the right gear size.
Unread 09-02-2011, 17:58
Matt C's Avatar
FRC #1468 (J-Birds)
Re: Old Motors
Back to the drawing board.
Those things weren't all that powerful anyway.
Unread 09-02-2011, 17:59
Lead Programmer
AKA: Josh
Re: Old Motors
Any Ideas to change the gear on the window motor?
Unread 09-02-2011, 18:01
Matt C's Avatar
FRC #1468 (J-Birds)
Re: Old Motors
The worm gear of the Denso motors are considered part of the motor and cannot be modified.
<R47> Motors and servos used on the ROBOT shall not be modified in any way, except as follows:
A. The mounting brackets and/or output shaft/interface of the motors may be modified to facilitate the physical connection of the motor to the ROBOT and actuated part.
B. The electrical input leads on the motors may be trimmed to length as necessary.
C. The locking pins on the window motors may be removed.
D. The connector housings on the Window motors (PN 262100-3030 and 262100-3040) may be modified to facilitate lead connections.
Unread 09-02-2011, 18:02
LLogan LLogan is offline
Head Screw Tightener/Cheerleader
AKA: Logan
FRC #1261 (Robolions)
LLogan has a spectacular aura aboutLLogan has a spectacular aura about
Re: Old Motors
Why would you want to change the gear?
Just put on the black coupler. Then it can accept a 5/8s keyed shaft.
