Re: Possible bad Jaguar.... Thoughts?
My first thought would be rather than just "swap out" the Jaguar with one off of the shelf, I would be inclined to physically remove the suspect Jaguar from the robot (disconnecting all of the wiring first) and then move the suspect Jaguar to the position of the other swerve Jaguar that is working correctly, swapping the "good side Jaguar" with the "bad side Jaguar." When doing this, the idea is that all of the cabling (power input, motor outputs, CAN/PWM, and encoder/limit switches, if relevant) do NOT move with the Jaguar. You want to move the "suspect Jaguar" to the position of the "good Jaguar" and use all of the cabling for the "good Jaguar." Similarly, put the "good Jaguar" into the position previously held by the "suspect Jaguar" using all of the cabling from the "suspect Jaguar." You can then retest the robot with the "suspect Jaguar" and the "good Jaguar" swapped. I see four possible outcomes from this, each of which would tell you something about what is wrong: A - the problem moves to the other side of the robot: this is almost surely a bad Jaguar. Contact TI to RMA the Jaguar (assuming it is a black Jaguar). B - the problem stays on the same side of the robot: the problem isn't with the Jaguar at all, but is being induced by mechanical or cabling issues C - the problem goes away completely and both Jaguars work fine in their new positions: there was likely a mechanical or electrical cabling issue (loose connection) that was fixed by the act of unconnecting and reconnecting everything D - neither Jaguar works: either the disconnect / reconnect was done sloppily and there is now a loose wire/cable on both sides, or there was some sort of mechanical/electrical issue on the "bad side" which had induced a fault in the suspect Jaguar and has now induced a fault in the previously good Jaguar, too. In any case, I'm curious to hear the results of your troubleshooting, whether or not you end up trying the swap I describe Best Regards, --ken Last edited by Ken Streeter : 09-02-2011 at 19:08. |
I've been experiencing similar symptoms and am trying to isolate it to the JAG. Strange symptom goes away when new JAG installed. Has happened once over the summer and am now isolating two different JAG problems in different functions in robot...both fixed when JAGs replaced...very frustrating. Will confirm the fault and RMA soon.
I did check all the wiring for obvious problems but didn't see any (I re-wago's all the connections). We didn't replace the bad Jag with a new one, since we didn't have a spare black one handy, and we may want to try using the CAM at some point, so we moved the adjacent one to the failing position, and replaced the moved one with a grey Jag that we had around. Prev: *BJ1*, BJ2, BJ3, BJ4 New: BJ2, GJ1, BJ3, BJ4 This did in fact eliminate the problem. We drove it hard for a while and did not see the fault re-occur. (note: this entire multi day process was performed with the wheels locked straight, with no actual means to rotate the swerve mechanism, so this was not a factor) We'll keep and eye on this (and may in fact put the "bad" Jag back in pos 2 to verify), but I'm 95% convinced at this point that it's a Jag fault. Phil. |
Glad to hear that your swap worked and that you're off and running again. I would highly suggest that you follow the RMA procedure to return the black Jaguar to TI, as described at http://forums.usfirst.org/showthread.php?p=44255 I'm curious to hear what the problem ends up having been. Best regards, --ken |
The forum software truncates the URL for some reason. Click Here for the RMA form.
Follow the procedure here but use the form link above. -David |
