#9
Re: Problem with jaguar's "loss of servo link"
Can you take a picture of your electronics board and wiring?
There are a number of things I can think of, any one of which could cause the problem. You didn't enable the robot on the driver station You didn't plug the PWM cables from the jaguar to the digital sidecar PWM ports You didn't power the digital sidecar The digital sidecar isn't plugged into the digital module in slot 4 of the cRIO You have the PWM cables plugged in backwards. B is for black wire. You have the PWM cables plugged into the wrong PWM ports on the digital sidecar. The flash rate of the green LED next to the RSL may be a clue. What pattern is it flashing? Last edited by Joe Ross : 09-02-2011 at 20:04. |
