Originally Posted by 3286
EDIT: We have been getting the same error message over and over again. From the picture on the first post there says there is a conflict but we can't locate the conflicts. Is there any way to check where the conflicts are located? We've tired backtracking them manually but to no avail.
The "conflict" is between the code that's already running on the cRIO and the code that you're deploying to it. You're telling the system to accept a "Real-Time Startup Application", and it's letting you know that there are things running that it will have to stop in order to continue. That is a normal part of the process. It isn't an error message. Don't worry about it.
