Re: Changing default values
It seems when I run the code I couldnt do that because just one of the motors works! |
Your description doesn't seem to be giving us enough information. Can you attach a copy of your vi, or at least show us a picture of your program so we can look at it?
I double click on one of the victors and change its PWM channel and set that as the default value from that window. Also the other victors PWM default value changes. How can I solve this problem. |
I only see one victor open in the begin.vi you posted. Maybe that's why only one victor works.
Sorry I uploaded the wrong code! We figured out that one of the victors was burnt out.
Your code looks perfect. There's no reason to make the values "default", wiring up constants is fine.
(You might want to have your motor names be more description than "motora" though) |
#7
What you need to do is set these values to constants in your Begin.vi, in the same manner that the Default Framework does. |
#8
Oh! Thanks, David, now I see what he's talking about.
To change the PWM channel assigned to a Victor, you don't mess with anything inside the Motor Open vi. You change the value of the constant wired to its PWM channel input terminal. Hover the cursor over the constant until it turns into a hand icon, then you can use the constant as a popup menu and select the channel you want to use. As a general rule, you should never be changing anything inside the library VI functions. |
#9
And FYI, this was the clue.
