Go to Post Isn't that the connector used on the F.L.U.X. Capacitor? - Ed Sparks [more]
Unread 08-02-2011, 22:17
Daniel_H's Avatar
Daniel_H Daniel_H is offline
FRC #1156 (Under Control)
Daniel_H is just really niceDaniel_H is just really niceDaniel_H is just really niceDaniel_H is just really nice
No inventor studio this year?
Am I the only one whose Inventor Studio is grayed out at inventor 2011? I've tried lots of different parts and assemblies and its unavailable in all of them.
If its only with me, can anyone help me (re)enable it? I have no idea how it got turned off
[<o>] gogogo [<o>]
http://undercontrol1156.com/
Unread 09-02-2011, 15:22
JD Mather's Avatar
JD Mather JD Mather is offline
JD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the rough
Re: No inventor studio this year?
It should work fine.
Check your Add-ins and see that it is loaded.
Did you turn off UAC before install?
Have you installed Service Pack1?
Autodesk Inventor Certified Expert
Certified SolidWorks Professional
AU 2007 Avatech Altogether Smarter Inventor Challenge 1st Place
http://home.pct.edu/~jmather/content..._tutorials.htm
Unread 09-02-2011, 15:34
Daniel_H's Avatar
I checked the add-ins and it says "Startup/Loaded", as most items in this tab. Nonetheless, it's grayed out. I tried unloading it and I realized it disappears from the Environments tab. I reloaded it afterwards and it didn't help, still shows up there but grayed out
UAC is always off here, so yes.
Communication center tells me that my software is up to date. I couldn't find anywhere else to figure out if I have SP1, but I remember (vaguely) downloading something like that just after I installed it.
I don't know what else to do..
[<o>] gogogo [<o>]
Unread 09-02-2011, 22:23
JD Mather's Avatar
Post a screen shot.
Unread 09-02-2011, 22:49
MishraArtificer's Avatar
MishraArtificer MishraArtificer is offline
Winner, Chief Delphi Insanity Award
AKA: Jeremy Marr
FRC #0240 (T.E.M.P.E.S.T.)
MishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of light
SP1 for what? Windows 7? That's still in beta, man.
Madness?
THIS IS F.I.R.S.T!
Unread 09-02-2011, 23:03
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
No, the service pack for Inventor.
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 10-02-2011, 07:24
JD Mather's Avatar
http://usa.autodesk.com/adsk/servlet...linkID=9242019
Unread 15-02-2011, 19:43
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
Daniel,
I just checked the Autodesk website and could not find any similar issues to the one you are having. You have some suggestions from other folks (thanks all), so let see if any of those work.
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
Unread 15-02-2011, 22:42
Daniel_H's Avatar
Originally Posted by inventor_phild View Post
Daniel,
I've tried it all, none worked. I'm thinking about uninstalling and reinstalling using the dvds that came in the KOP this time (the first time I downloaded from autodesk website)
would I be able to use the same license?
[<o>] gogogo [<o>]
Unread 16-02-2011, 10:54
JD Mather's Avatar
You might try a Repair install before uninstall/reinstall.
If you go the uninstall route search google for Autodesk Inventor Clean Uninstall instructions and follow closely.
If it is the same version you can use the same serial number.
Unread 23-02-2011, 18:12
Daniel_H,
Any success to report?
Phil Dollan
Autodesk Inc.
Unread 10-03-2011, 11:04
Daniel_H's Avatar
Daniel_H,
Today I used the Autodesk Inventor Clean Uninstall, downloaded it again from autodesk student community and reinstalled it.
No success. Inventor Studio is not even grayed out this time, it simply doesn't appear in the environments tab. I clicked in "Add-Ins" and Inventor Studio appears as Loaded and Loaded on Startup.
[<o>] gogogo [<o>]
Unread 29-03-2011, 01:05
Daniel_H's Avatar
I uninstalled again, and this time I installed using the kit's Inventor DVDs to install. The problem persists.
There are two possibilities:
1 the problem is my cd-key, which I got at autodesk student community.
2 there's something in my computer. My hardware is pretty good (HP dv6-2190us), so could be something in the OS or who knows what else
[<o>] gogogo [<o>]
Unread 29-03-2011, 06:52
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
I have had the same problem but with Inventer 2010. I just brought home 2011 from the KOP and will try installing that.
Hope it works.
Daniel_H:
It's nothing with your computer.
I just bought a Dell XPS 15 with an Intel i7. So it's nothing with your computer.
