Go to Post I blame FIRST for being the best thing that has happened to me. - vivek16 [more]
Unread 10-02-2011, 00:58
Jim Zondag's Avatar
Jim Zondag Jim Zondag is offline
Team Leader
FRC #0033 (Killer Bees)
Jim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond repute
pic: In_CIM_erator
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Re: pic: In_CIM_erator
did you look at the specs for those rs775's at 12 volts, at 18 volts they are pretty good, but at 12 volts they produce a measly 70 watts.
Unread 10-02-2011, 00:59
Aren_Hill's Avatar
Build Nifty Things
The 12v VERSION at 12v produces the measly 70 watts,
The 18v VERSION at 12v produces much more than that
http://banebots.com/docs/M7-RS775-18-AT12V.pdf
A guy who likes robots.
Unread 10-02-2011, 01:10
Justin Montois's Avatar
Justin Montois Justin Montois is offline
FirstUpdatesNow.com
FRC #3015 (Ranger Robotics)
Justin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond repute
Send a message via AIM to Justin Montois
lol I'm quite sure they did.
@jmontois340
Team 3015
2016- World Championship Finalists and Tesla Division Champions with 2056, 1690 and 1405
2016- Greater Pittsburgh Regional Chairman's Award
2016- Pittsburgh Regional Finalists with 1023 and 4050
2015- Newton Division Finalists With 195 and 1756
2015- Finger Lakes Regional Champions with 4039 and 378
Unread 10-02-2011, 01:24
AKA: Isaak
Team Role: CAD
pretty sure the 18 volt version is the same, we ran ours and found it MUCH weaker than the RS 550, if anything the 18v version should be weaker than the 12V version, the only difference is the gauge of wire.
Unread 10-02-2011, 01:26
Aren_Hill's Avatar
Build Nifty Things
Any quantitative tests? lifting a load, dynamometer...those spec sheets don't magically appear out of thin air.
Unread 10-02-2011, 01:36
AKA: Isaak
Team Role: CAD
here is the link to the actual source of the motors, BaneBots Buys them from here, and according to this spec sheet
http://www.mabuchi-motor.co.jp/cgi-b..._ID=rs_755vcwc
the "BaneBots rs775 at 12 volts" does somewhere barely above 200 watts at 14.4 volts. the 18 volt version does somewhere around 70.
I am fairly sure that the numbers on BaneBots website are inccorrect, they do match up with a larger motor from this supplier.
http://www.mabuchi-motor.co.jp/cgi-b..._ID=rs_775vcwc
this is the larger motor, but as you can see it is not sold in a 12 volt version, so the 70 watts is close to what this would produce at 12 volts as well, none of the Mabuchi specs come even close to the BaneBots specs.
Unread 10-02-2011, 01:56
AdamHeard's Avatar
Lead Mentor
I think you're confused a bit. Motors are spec'd at a voltage, but will run at any voltage (although, they won't last long once you hit a certain voltage).
A motor rated for 18V will run fine on 12V, it will just be roughly 4/9 the power of it on 18V.
Unread 10-02-2011, 02:00
AKA: Isaak
Team Role: CAD
i am aware, but (4/9) times to 200 watts max power that the supplier has tested for still leaves less than 100 watts of power, unless it is the 14.4 V nominal opperation motor, in which case it will output around 70 watts. according to the people who made the motors, there is no way any of them that size will output more than 100 watts at 12 volts.
also, power is current * Voltage
according to the Bane Bots website peak efficency current is 5.7
5.7 * 12 is 68, which fits the 70 watt power output number, i think all the other info on the BaneBots website is correct, except the power calculation, think that was taken at 18 volts.
Unread 10-02-2011, 02:10
AdamHeard's Avatar
Lead Mentor
The mechanical output power can be calculated from torque times speed.
If you take the motor at half free speed, it is also at half stall torque, for the 775 this works out to over 250W of power.
Unread 10-02-2011, 02:13
John G John G is offline
FRC #0399 (Eagle Robotics)
John G is on a distinguished road
Where did the 4/9 come from. I must have missed something in my math.
Unread 10-02-2011, 02:17
AdamHeard's Avatar
Lead Mentor
Mechanical power is torque x speed.
Stepping down from 18 to 12V is a 2/3 change.
Power = 2/3Torque x 2/3 speed. Works out to the power at 12V being 4/9 that of 18V.
Unread 10-02-2011, 02:18
AKA: Isaak
Team Role: CAD
none of the motor specs on the maubichi sheet indicate a power rating of more than 200 watts at 18 volts. thus i dont think it is possible for the 775's to output more than 133 watts MAXIMIUM negating friction.
Unread 10-02-2011, 02:22
Ok. I did Power = w/t; w = Fd; F = torque *r. I thought distance and time would stay constant, so I ended up with 2/3 by just changing the torque. Thank you.
Unread 10-02-2011, 02:32
ttakashima's Avatar
ttakashima ttakashima is offline
T^2
AKA: Travis
FRC #2504 (The Governors)
ttakashima has a spectacular aura aboutttakashima has a spectacular aura about
the 18v - RS775 WC version is supposed to output 273.03 W of power at max eff. - 18v
the 18v - RS775 VC Version outputs 208 W or power at max eff. - 18v
here is the spec sheet are ya looking at this one?
The 775 VC outputs 41.4 W at 12v - 5.7A and 775 VC outputs 156 W at 12v - 18.7A
the 775 WC outputs 168 W at 12v - 18.7A and 775 WC outputs 39.9 W at 12v - 5.7A
Travis Takashima
Team Leader: Team 4270 - 2016-beyond
Mentor and Team Leader: Team 2504 - 2009-2016
Team 2504 Alum 09'
Attending
-FIRST BAE Systems Hawaii Regional
