Go to Post Once we know how magic works it's no longer magic; it becomes science. - Karthik [more]
Unread 10-02-2011, 07:44
sam_who sam_who is offline
FRC #2190
sam_who is an unknown quantity at this point
Re: Potentiometer voltage range?
You could power a 10-turn pot with 12 volts. That will give you 1.2 volts per turn.
CAUTION! If you choose this method, you must ensure not to go past ~4 turns or you risk burning the input (for starters). Also, you have to use the lower end of the pot (0-4.8 volts) rather than the upper (7.2-12 volts).
Finally, take the advice offered earlier and get a higher value pot.
