#16
Re: Programming Mecanum?
Cartesian/Polar will only work if your wheels are similar to
\/ /\ or /\ \/ I'm not sure in which order though. Our team made the mistake of putting our mecanum wheels straight on all four sides so that's something we had to program around. @Esther: I managed to get the drive train programmed with your help. Thanks so much! ![]() *edit* my bad, I mean Ether. Last edited by Robby Unruh : 10-02-2011 at 09:09. |
#17
The wheels are supposed to be "straight", i.e. the plane of all 4 wheels should be parallel to each other. The rollers on each wheel are at a 45 degree angle to the plane of the wheel, and should form a visual pattern that looks like this when viewed from the top: Code:
\...../ ..... ..... ..... /.....\ ... or this when viewed from the bottom: Code:
#18
Oh, alright. I guess I must've misunderstood some posts around here. Thanks for clearing that up.
