Go to Post Things are not always as simple as they seem. - Paul Copioli [more]
Unread 10-02-2011, 08:43
dmitch's Avatar
dmitch dmitch is offline
Chief Head Electrical Guy
AKA: Daniel Mitchell
FRC #1997 (Stag Robotics)
dmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the rough
Re: Programming Motors for Arm
How will I determine the correct voltage when I get the arm position I want? And then for the process variable, which I understand to be the actual position of the pot, you mentioned an array; is this preset in the PID or will I have to do something extra for that?
Unread 10-02-2011, 08:56
You physically position the arm where you want it, then measure the pot output in LabVIEW (front panel indicator or probe), or you use a multi-meter to get your voltage reading.
Unread 10-02-2011, 09:21
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Another option is to first convert your potentiometer voltage to an angle (The relationship should be of the form angle=m*voltage + offset). You can then use that angle to calculate the height of your arm end effector (you'll likely need to draw out the geometry to arrive at the correct equation). Your presets could then be set in inches from the floor.
Unread 10-02-2011, 09:01
MaxMax161's Avatar
MaxMax161 MaxMax161 is offline
Allegedly Useful
AKA: Max Llewellyn
FRC #2791 (Shaker Robotics), FRC #1676 (Pascack π-oneers)
MaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond repute
Here's a quick .vi I wrote to learn about PIDs. It's not perfect but it allows you to simulate what a motor using a PID would look like. I think I did a decent job labeling everything, if not feel free to PM me and I'll explain anything you need.
I've already uploaded this in a different thread, here's the link. http://www.chiefdelphi.com/forums/sh...ad.php?t=90604
2791 Shaker Robotics (2013-present)
--Control Systems Mentor 2013-present
--Drive coach 2015-present
1676 The Pascack π-oneers (2010-2013)
--Drive coach 2011-2013
--Lead Programmer 2011-2013
