Go to Post The version that finished nationals was about 50% aluminum and 50% the original PVC and we never had any member break. (structural member, not team member). - Gary Dillard [more]
Unread 02-10-2011, 07:59 AM
Robby Unruh's Avatar
Robby Unruh Robby Unruh is offline
*insert random dial-up tone here*
FRC #3266 (Robots R Us)
Robby Unruh will become famous soon enough
Re: Programming Mecanum?
Cartesian/Polar will only work if your wheels are similar to
or
I'm not sure in which order though. Our team made the mistake of putting our mecanum wheels straight on all four sides so that's something we had to program around.
@Esther:
I managed to get the drive train programmed with your help. Thanks so much!
*edit* my bad, I mean Ether.
[Robots R Us #3266]
2015: Georgia Southern Classic (Winners / Thanks 1319 & 1648!), Queen City
2014: Crossroads, Queen City
2013: Buckeye, Queen City, Crossroads
2012: Buckeye, Queen City
2011: Buckeye
2010: Buckeye
Unread 02-10-2011, 08:42 AM
The wheels are supposed to be "straight", i.e. the plane of all 4 wheels should be parallel to each other.
The rollers on each wheel are at a 45 degree angle to the plane of the wheel, and should form a visual pattern that looks like this when viewed from the top:
... or this when viewed from the bottom:
Unread 02-10-2011, 09:11 AM
Oh, alright. I guess I must've misunderstood some posts around here. Thanks for clearing that up.
[Robots R Us #3266]
2011: Buckeye
2010: Buckeye
