Go to Post I don't have enough vacation time for them to start allowing video replay. - TJP123 [more]
Unread 05-02-2011, 11:56
mkadonoff's Avatar
mkadonoff mkadonoff is offline
Programming Mentor
AKA: Mark Kadonoff
FRC #0620 (Warbots)
mkadonoff is an unknown quantity at this point
Question Broken Trim Knobs on Photoswitches?
We are concerned that the trim knobs on our photoswitches have been broken by being turned past their limits. We can turn them continuously. Should they only be able to rotate approximately 270 degrees?
Mark Kadonoff
Programming Mentor
JMHS Warbots Team 620
2009 DC Regional Finalist
2013 Pittsburgh Regional Finalist
Unread 05-02-2011, 16:36
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
Re: Broken Trim Knobs on Photoswitches?
We could turn ours 360+, and they're not broken
Unread 10-02-2011, 00:25
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Originally Posted by nckureghian14 View Post
It is made to turns 360 degrees.
Definitely not true, there are stops on them. However, I don't think it hurts them too much if you don't do it too often. I try to avoid it though (try using only the head of the screwdriver, if it's removable, so you get a smaller mechanical advantage and you can feel the stops).
Unread 10-02-2011, 09:18
Mark,
I have had one mentor report that he broke the knob by rotating it too far. He was able to remove the damaged knob and found that a Phillips screw driver was all he needed to make the calibration.
Unread 14-02-2011, 23:55
WizenedEE's Avatar
AKA: Adam
Mark,
I can confirm this. Saving $65 by removing a piece of plastic is good. It's really simple to pull off and it's not all that much more difficult to turn with the knob off.
