#16
Re: Mecanum Einstein this year
The best most practiced drivers will make it to Einstein just like every year. It doesn't matter what kind of drive it is.
#17
Mecanum's advantage is not in a flat field, it's in a tight area where you don't have room to change your orientation. FIRST never has a field with so many obstacles that you can't re-orient. Mecanum will be an equal the same this year as in past years. Mecanum serves no practical advantage on a FIRST field. Nothing has changed that this year. Just like the past, we will not see a mecanum bot on Einstein. |
#18
67 in 2005 had 3 wheels and did not swerve they drove their bot with a steering wheel and used the back wheel to "steer" their bot around.
#19
I thought it would happen in 2010 not on merit but on sheer volume, yet the alliances with no mecanum robots consistently won. I suspect 2011 may break the cycle, not because mecanums are at an advantage but because of luck and volume. I believe all three wheels were turreted. Last edited by Chris is me : 10-02-2011 at 10:43. Reason: teams - > alliances |
#20
http://www.chiefdelphi.com/media/photos/20540 |
#21
One of the few pictures in CD-Media that has a reasonably clean shot of their drivetrain: http://www.chiefdelphi.com/media/photos/21750 It looks like they had a mode that would make the robot 2WD plus one pivoting driving wheel--that shot seems to say they've got 2 fixed and one pivot.
But the better shot is http://www.chiefdelphi.com/media/photos/20540, before all that shielding went on. Definitely a 3-wheel swerve. Fun fact: of the 5 swerve drives on Einstein, only 2 were standard 4WD swerves (71 and 111). 2 were 3WD (67, 16), and one was a 6WD swerve (1625). 2 won the event (67, 111). I don't remember a single swerve on Einstein in 2006. |
#22
Sorry about that. I knew you did them last year and looked at a pricture from 2008 and I guess I saw what I wanted to and expected to see.
#23
I am going to say that we will not see a mecanum robot on einstein.
#24
I am going to disagree with anyone making a blanket statement and say that, while it is more likely we will see a mecanum on Einstein this year than in previous years due to volume and increasing repository of good code/driving ability, we should reserve categorical judgment until Einstein actually, y'know, happens.
#25
I think there's a good chance we will see a mecanum on Einstein this year. Not because they have any inherent advantage in this game (they don't), but because out of the many teams that have chosen that drivetrain this year, there is a decent chance that one of them will end up in the 12 teams on Einstein. Their drive won't be the thing that gets them to that point though - it'll be on the strength of their other mechanisms.
#26
Figured I'd hunt this down to say: Nope
#27
#28
Didn't 51 have mecanum this year?
#29
I believe it was a "slide drive", the no traction wheel version of a nonadrive, so 5 omni's
#30
I believe Aren's correct. Also, 2826 was VERY close to breaking the mecanum curse on einstein (although, they did use a jump drive to switch between mecanum and 6wd).
