Go to Post Remember, there are many differents path to obtaining knowledge. There's no need to pigeonhole the process. - Karthik [more]
Unread 08-02-2011, 19:02
Osprey1 Osprey1 is offline
FRC #1318
Team Role: Photography
Osprey1 is an unknown quantity at this point
NXT Compass Invalid Manufacturer Exception
When we plugged in our compass to the I2C port on the digital sidecar, we got an Invalid Manufacturer Exception. We double checked the connection and everything seems right. We then installed a jumper configuration on the sidecar and now everything on the robot stops when the compass object is created. Is anyone else getting this error? Did you fix it?
Unread 10-02-2011, 11:33
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
Re: NXT Compass Invalid Manufacturer Exception
What language are you using?
Unread 10-02-2011, 12:23
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
We are, and no we haven't fixed it, it's an issue with the WPI library.
This happens in C++.
I believe it might be due to the typo found in HiTechnicCompass.cpp. I haven't tried correcting this typo to see if it works without throwing an exception but this is probably the issue.
Originally Posted by WPILibC++Rev2259
HiTechnicCompass::HiTechnicCompass(UINT32 slot)
	: m_i2c (NULL)
	DigitalModule *module = DigitalModule::GetInstance(slot);
	if (module)
		m_i2c = module->GetI2C(kAddress);
		// Verify Sensor
		const UINT8 kExpectedManufacturer[] = "HiTechnc";
		const UINT8 kExpectedSensorType[] = "Compass ";
		if ( ! m_i2c->VerifySensor(kManufacturerBaseRegister, kManufacturerSize, kExpectedManufacturer) )
			wpi_fatal(CompassManufacturerError);
			return;
		if ( ! m_i2c->VerifySensor(kSensorTypeBaseRegister, kSensorTypeSize, kExpectedSensorType) )
			wpi_fatal(CompassTypeError);
It shouldn't affect compass operations though.
Unread 11-02-2011, 01:58
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
So at least for the HiTechnic compass that I have, that's exactly what the sensor outputs. If yours reports something different, please let me know so I can update the libraries.
For a quick test, just use I2C directly to query those 2 registers just like the library does and then print it out and post it here.
Thanks,
-Joe
