Go to Post If you're the smartest person in the room, you're in the wrong room! - Ian Curtis [more]
Unread 10-02-2011, 14:54
Rangel's Avatar
Rangel Rangel is offline
John Rangel
FRC #0842 (Falcon Robotics)
Rangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond repute
How to configure newly bought radio?
Hello, my team had burnt out a radio due to not checking wiring and so we bought a new one that just came in. However, it seems to be a different firmware. What is the correct firmware I need in order to configure the radio. Right now the setup tab in the radio configuration is different from the manual found on the kop.
2012 Dean's List Winner
2011-2014 Arizona Regional Winners
2016 Las Vegas Regional Winner
2014-? Mentor
Unread 10-02-2011, 15:01
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: How to configure newly bought radio?
I believe the firmware on your device should work fine.
If you click on "Wireless" on the left side of the page in your image I'm guessing you will get a page very similar to either Step 5 or Step 6 of the configuration document.
Unread 10-02-2011, 15:02
The firmware on ours out-of-the-box was 1.21 the same as yours.
Unread 10-02-2011, 16:12
Rangel's Avatar
John Rangel
Thanks, I fixed the problem. Turns out somebody set the router to auto instead of AP.
2014-? Mentor
