Go to Post An amazing manipulator system is worthless without being able to drive reliably. - RoboChair [more]
Unread 10-02-2011, 15:10
xinchi.he's Avatar
xinchi.he xinchi.he is offline
AKA: Xinchi He
FRC #1209
xinchi.he is an unknown quantity at this point
Send a message via MSN to xinchi.he
Have problem on getting analog values from lane tracking sensor
Hi everyone. I am new here. Here I met with a problem for sensors. My professor would like to use the analog sensor to receive the brightness of the black and white which means I should get values with a range from 0 to 700 whatever. But I couldn't find the method to access it. Anyone could help??
THXX!!!!!!
We are not using the digital sensor that provided by FIRST, instead we use our analog sensor which should plug to the analog side card. Is there a method that in java that could access to the analog value it returns??
Unread 10-02-2011, 16:06
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: Have problem on getting analog values from lane tracking sensor
the line tracking sensors as found in the kop are not analog, they are simply digital inputs that return true or false. You can customize the threshold on them, but you can't get more detail unfortunately.
Watchdog.Kill();
Unread 10-02-2011, 16:35
xinchi.he's Avatar
AKA: Xinchi He
FRC #1209
Thanks a lot! But we are not using the digital sensor that provided by FIRST, instead we use our analog sensor which should plug to the analog side card. Is there a method that in java that could access to the analog value it returns??
Thanks!!!!
Unread 12-02-2011, 06:03
michael714's Avatar
michael714 michael714 is offline
FRC #3863 (Pantherbotics)
michael714 is on a distinguished road
If you have an analog sensor, just plug it into the one of the analog ports on the analog breakout. If your sensor provides an analog value, you could just use GetAnalogIn() (you can find more in the WPI lib reference or the java docs).
Aside from that, you should really be using the provided line sensors. It looks like there will not be a strong contrast in colors between the line and the carpet. However, the line is reflective and the included line sensors work perfectly even from 6 to 12 inches high!
Unread 12-02-2011, 09:23
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
1. Import AnalogChannel
2. Use this is to initialize the sensor:
AnalogChannel color = new AnalogChannel(channel number);
3. Use this to read the value:
System.out.println(color.getValue());
That'll probably take a ton of testing to figure out what darkness is what but you'll get there with enough work.
Unread 12-02-2011, 11:34
DCRich DCRich is offline
FRC #2180 (Zero Gravity)
DCRich is an unknown quantity at this point
THXX!!!!!!
Note that the Analog input channels are -10 v to +10 v voltages outside that range will be over-range and may not read correctly.
The default IR sensors put out 1 v low and 12 volt high so they are not true digital signals. If you run 12 v into the GPIO lines it will look digital but it is over the max input value and could cause the line to fail. You should check the voltage and make a divider to drop the signal levels down to the 5 v level required.
Unread 12-02-2011, 11:45
The default lane-tracking sensors are just NPN switches (hi/lo impedance). They are not intended to source any voltage.
Hook it up as follows:
brown wire to +24volts (solenoid breakout)
blue wire to ground
White wire to a DIO input
The internal pullup on the DIO provides the voltage. The switch just shorts out the voltage (provided by the pullup) to provide the digital hi/lo signal.
Unread 12-02-2011, 14:38
garyk garyk is offline
Programming Mentor: 668, 972, 2643
FRC #0668 (Apes of Wrath)
garyk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the rough
blue wire to ground
The KOP optical sensors are part number 42EF-D1MNAK-a2. The paper data sheet and the plastic bag in which they come says they require 11 - 30 VDC. We have then running fine on 12V from the power distribution board. There's no reason to hook them to 24V. You should save the 24V for the cRIO and the pneumatic solenoids.
Silicon Valley Regional 2005, 2006 972
Silicon Valley Regional 2007 668 Xerox Creativity Award
Championship Event 2007 668
Portland Regional 2008 668
Silicon Valley Regional 2008 668, 972
Beta Test Team 2008 668 (with 100 & 254)
Silicon Valley Regional 2009 668 Regional Chairman's Award; 2643
Sacramento Regional 2009 668 Winning Alliance (thanks, 1717 & 2473!), 2010 Winning Alliance 3256
CalGames 2006, 2007, 2008, 2009, 2010, 2011 Field Tech
NorCal FTC Regional 2008, 2009 Inspector
Championship Event 2009
San Diego, Silicon Valley Regionals; Champ. Event 2010 668, 2643, 3256
Silicon Valley, Madera Regional 2012 2643
WRRF Programming Instructor 2006-2016
Regional Woodie Flowers Award 2014 2643 Utah Regional
Unread 12-02-2011, 14:41
Do a little searching in the forums and you'll see why I said to use 24V.
