Go to Post For example, you can make a car as safe as possible. It may get the highest safety ratings in it's class, but if you drive it off of a cliff there really isn't much you can do about that. - jmanela [more]
Unread 10-02-2011, 15:09
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
Better bitwise conversion
Hello,
I am working on a program to control an arduino from a ds, and I have this code that converts all of the button input bools to a byte.
				//pack buttons into a byte
				if(keysHeld() & KEY_A) {
				    amount += 1;
				} else if (keysHeld() & KEY_B) {
				    amount += 2;
				} else if (keysHeld() & KEY_Y) {
				    amount += 4;
				} else if (keysHeld() & KEY_X) {
				    amount += 8;
				} else if (keysHeld() & KEY_L) {
				    amount += 16;
				} else if (keysHeld() & KEY_R) {
				    amount += 32;
				} else if (keysHeld() & KEY_START) {
				    amount += 64;
				} else if (keysHeld() & KEY_SELECT) {
				    amount += 128;
				} else {
				    amount = 0;
amount is a byte.
How can i do this more elegantly?
Unread 10-02-2011, 17:13
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: Better bitwise conversion
Is there a reason why you are translating one bit position to another? It looks like keysHeld() is already returning a bit per key. Can't you just do the following?
amount = keysHeld();
The only difference is keysHeld() can return more than one bit set and "amount" in your code can only have one bit set.
If you want to isolate one bit from all the set bits returned by keysHeld(), you can do this:
int rawBits = keysHeld();
int amount = rawBits & ~(rawBits ^ -rawBits);
Or is keysHeld() returning more than one byte (e.g. 16-bit) and you are trying to compress it into one byte? If so you may do the following:
byte amount = 0;
if (rawBits & KEY_A) amount |= 0x01;
if (rawBits & KEY_B) amount |= 0x02;
if (rawBits & KEY_Y) amount |= 0x04;
if (rawBits & KEY_X) amount |= 0x08;
if (rawBits & KEY_L) amount |= 0x10;
if (rawBits & KEY_R) amount |= 0x20;
if (rawBits & KEY_START) amount |= 0x40;
if (rawBits & KEY_SELECT) amount |= 0x80;
Just curious, these looks like xbox controller buttons, what are you trying to do?
Unread 10-02-2011, 20:19
1 * 4 != 14
its for a ds interface to an arduino robot my team is working on
Unread 10-02-2011, 20:32
dbeckwith's Avatar
dbeckwith dbeckwith is offline
Lead Programmer
AKA: Daniel Beckwith
FRC #3205 (The Patriots)
dbeckwith is an unknown quantity at this point
Well one way you could do it is with a for loop, but that would only really be efficient if the bit masks are consecutive. I only know Java, so I might get the C++ syntax wrong, but here is what it might look like:
int keys = keysHeld();
byte packedKeys = 0;
for (int i = 0; i < 8; i++) {
  if (keys & (1 << i)) packedKeys |= 1 << i;
That would pack the values of the keys, but only if the bit masks were all in a line. You could also start the i variable at the first mask if it isn't zero. I have the same question as mikets though. Why do you even need to do this if keysHeld() already returns the key values? It seems redundant to me.
q = (2*b) | ~(2*b);
if (life.getLemons() != null) this.lemonade = new Drink(life.getLemons());
else throw new NoLemonsException("What now?");
Unread 10-02-2011, 21:21
mikets's Avatar
Software Engineer
But this for-loop is copying the exact same bit pattern from keys to packedKeys. So what's the difference between that and this?
packedKeys = keys;
Unread 10-02-2011, 21:59
demosthenes2k8's Avatar
demosthenes2k8 demosthenes2k8 is offline
Graduated but not gone
AKA: Matt Soucy
FRC #0166 (Chop Shop 166)
demosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to behold
Send a message via AIM to demosthenes2k8 Send a message via Yahoo to demosthenes2k8
keys stores them differently, according to this:
typedef enum KEYPAD_BITS {
  KEY_A      = BIT(0),  //!< Keypad A button.
  KEY_B      = BIT(1),  //!< Keypad B button.
  KEY_SELECT = BIT(2),  //!< Keypad SELECT button.
  KEY_START  = BIT(3),  //!< Keypad START button.
  KEY_RIGHT  = BIT(4),  //!< Keypad RIGHT button.
  KEY_LEFT   = BIT(5),  //!< Keypad LEFT button.
  KEY_UP     = BIT(6),  //!< Keypad UP button.
  KEY_DOWN   = BIT(7),  //!< Keypad DOWN button.
  KEY_R      = BIT(8),  //!< Right shoulder button.
  KEY_L      = BIT(9),  //!< Left shoulder button.
  KEY_X      = BIT(10), //!< Keypad X button.
  KEY_Y      = BIT(11), //!< Keypad Y button.
  KEY_TOUCH  = BIT(12), //!< Touchscreen pendown.
  KEY_LID    = BIT(13)  //!< Lid state.
} KEYPAD_BITS;
GSR Dean's List Finalist 2011
