Go to Post We're 30 pounds over LOL. I probably shouldn't be lol'ing, but it is 11:52PM, I just got home from a 15 hour build session, and I find the word 'potato' funny. - ZakuAce [more]
Unread 10-02-2011, 15:31
DSST\neal.ian DSST\neal.ian is offline
AAHHH!! WHERE'D ALL THE TIME GO?!?!
AKA: Ian Neal
FRC #2240 (Brute Force)
DSST\neal.ian has a spectacular aura aboutDSST\neal.ian has a spectacular aura aboutDSST\neal.ian has a spectacular aura about
Send a message via AIM to DSST\neal.ian Send a message via MSN to DSST\neal.ian Send a message via Yahoo to DSST\neal.ian
Question Manipulating throttle output (function)
This isn't a question on how to program or anything, but more of a mathematical question (I put it here because I figured this was more oten visited). My question is this: what is a function/equation I can use to change what the lower bound on the throttle is? I know that it gives outputs from -1 to 1 and to use it I need to negate the value that comes out, since "up" is -1. I figured out a function to manipulate the throttle inputs to get values from 0 to 1, which was (Z+1)/2, of course multiplied times -1 to give the right values. Any thoughts, or questions? Did this make sense at all? Thanks.
-2010 Finalists! CO Regional 2010
2240 BRUTE FORCE!!!!!!!
Our site: http://robotics.scienceandtech.org
Unread 10-02-2011, 16:01
AKA: Ian Neal
Re: Manipulating throttle output (function)
To clarify, I want a function in terms of X, Z, an W, where X is the new lower bound, Z is the throttle's raw output (or inverted, it doesn't matter), and W is the new output from X to 1.
Unread 10-02-2011, 16:23
Aaron V Aaron V is offline
FRC #1325 (Inverse Paradox)
Aaron V is an unknown quantity at this point
So as I understand what you're asking: you basically want to scale the range of -1 to 1 to, say, X to 1.
You're totally right in your (Z + 1) / 2 as a start. (The general equation for values not between -1 and 1 is: (Z - oldMinimum) / (oldMaximum - oldMinimum) assuming Z is you value. If you want to know more about why this is, let me know, but I don't think this is your main question). Now what this does is it gives you a value between 0 and 1 (always). Let's call this value P.
Now that you have this, you want to convert it to a new minimum. To get the new equation, you can just rearrange the old one to get: (newMax - newMin) * P + newMin.
So you can combine these things to get a general equation:
(newMax - newMin) * (Z - oldMin) / (oldMax - oldMin) + newMin
Or, you can do them separately if you want.
Unread 10-02-2011, 17:31
AKA: Ian Neal
Sweet! Thanks!
Unread 10-02-2011, 19:45
Originally Posted by DSST\neal.ian View Post
Sweet! Thanks!
No Problem
