Go to Post Although I'm 2-0 against 217 when Paul coaches, I'm 0-2 against them when he doesn't....hmmm.... :rolleyes: - Lil' Lavery [more]
Unread 10-02-2011, 19:48
avanboekel's Avatar
avanboekel avanboekel is offline
AKA: Adam Van Boekel
FRC #5934 (Gear it Forward, Crowbotics)
avanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant future
Tetrix Thermal-Protected DC Motor Power Cable Modifications
We were wondering if anyone knows if it is legal to modify the 'Tetrix Thermal-Protected DC Motor Power Cable'. We were thinking along the lines of cutting the wires and soldering them to the motor.
Any help would be greatly appreciated. Thanks!
Unread 10-02-2011, 20:43
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Re: Tetrix Thermal-Protected DC Motor Power Cable Modifications
If you try to solder, you will likely melt the plastic and ruin the connectors to the motor brushes. You would be better off using a strain relief on the power cord (zip tie?).
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 12-02-2011, 10:26
avanboekel's Avatar
Even if we could do this without melting anything, would it be legal? I think that we would be able to do it. We are just looking for it to be more reliable.
2338 Gear It Forward | Student 2010-2013 | Mentor 2014-Present | oswegofirst.org
2013 Wisconsin Regional Winner (1732, 111, 2338)
2013 Midwest Regional Dean's List Finalist
2015 Midwest Regional Chairman's Award Winner
2015 Archimedes Subdivision Winner (1023, 2338, 3996, 1089)
2016 Midwest Regional Chairman's Award Winner
4096 CTRL-Z | Mentor 2014 | team4096.org
5934 Crowbotics | Mentor 2016-Present | crowbotics.org
Unread 12-02-2011, 10:54
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
There's nothing that says you can't solder things on your minitbot. There's nothing that says you can't modify the motor cable. You do, indeed, need to be careful when soldering to the motor. Pre-tin both the motor pin and the wire with solder and then melt them together in the last step. A heatsink at the base of the motor pin would also be a good idea.
Unread 12-02-2011, 11:14
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Even if it was legal, what advantage would you gain by doing this?
-Michael Dessingue
Unread 12-02-2011, 16:17
avanboekel's Avatar
It's more reliable. We know that the wires will not fall out of thier connectors. We had this problem a lot with prototyping and didn't want to risk anything when it comes time for competition.
Unread 12-02-2011, 18:01
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
If you are pulling the connector of the motor you would probably yank the wires of the motor if their soldered.
You need to provide strain relief for your wires. Try cable tying the wires to the motor body and you shouldn't have any reliability problems.
Unread 13-02-2011, 13:59
Reliability is not a matter of if the product works how you want it to work, it is a matter of it is working as designed. In this case, I would believe the strain being applied to the cable is higher than it normally should be, thus disconnecting. If you give some strain relief to the connector by providing extra cable looped towards the motor and zip-tied, that should be a reliable fix for you.
Imagine though if you did solder the wire and the motor then failed, now not only do you have to replace the motor, but also the cable.
-Michael Dessingue
Unread 13-02-2011, 15:25
tagayoff's Avatar
tagayoff tagayoff is offline
FRC #3512
tagayoff is a jewel in the roughtagayoff is a jewel in the roughtagayoff is a jewel in the roughtagayoff is a jewel in the rough
If you solder wires on the motor be forewarned that the plastic holding the terminals is extremely heat sensitive and melts rather easily. The temperature required for lead free solder makes the plastic turn to jello. With the resulting moving of the terminals. And if they move the connection to the internal brush tab will likely be broken. Then you will need to open the motor rendering it useless for competition.
Unread 13-02-2011, 16:51
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
I did FTC in 2009 and noticed that even with a zip tie holding the wires onto the motor, the connectors are incredibly loose (they came that way) and tend to fall off. Pinching them a little smaller and using a strain relief would work though. Soldering works too (you can desolder of the motor fails). Just a matter of preference.
