Go to Post This is the first (and, if this stuff keeps up, last) time FIRST has allowed high-speed projectiles in years. Please use some common sense, people. - Madison [more]
Unread 02-10-2011, 09:28 PM
Eric24's Avatar
Eric24 Eric24 is offline
FRC #1138 (Eagle Engineering)
Eric24 is an unknown quantity at this point
Send a message via AIM to Eric24
Re: CAN Jaguar error [Solved]
I figured out that the issue was caused by running the smart dashboard because it took extra time to send the data to the dashboard. I simply commented out the dashboard code and the original wait time worked well. I might be able to modify the wait time for using the dashboard or set up a semaphore system, but it works well enough for now. Thanks for the help!
