Go to Post .....just don't hurt the programmer =) - mtaman02 [more]
Unread 01-15-2011, 02:25 AM
james7132
Posts: n/a
On Java an Line Sensing.
I don't know if I'm missing the obvious or not, but I can't seem to find a way to implement one of those three line sensors within our robot's program. Anyone tried this out yet?
Unread 01-15-2011, 02:57 AM
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
Re: On Java an Line Sensing.
If the example code they gave us is correct, they're just 3 digital inputs. You place them next to each other and determine which once have "input". If it's showing true, then it you basically assume that the line is under that particular sensor. Using this information, you can determine whether the line is on your left, your right, or if you're right on it.
However, you might want to wait for someone who's actually tried them out to give you an expert opinion. I don't even know what they look like this year because we've been busy designing all week.
Unread 01-15-2011, 12:20 PM
bakketti bakketti is offline
FRC #0443 (Freelance Robotics)
bakketti is an unknown quantity at this point
We got line tracking up and running last night. We didn't use the line tracker example in Netbeans but our code is similar. You pretty much need to access the three digital inputs with the DigitalInput get() method. Just like the example.
Unread 02-05-2011, 09:25 AM
1chess2u 1chess2u is offline
FRC #2771
1chess2u is an unknown quantity at this point
Where is this code?
Unread 02-05-2011, 12:06 PM
Its a little tricky. Start a new project and find the "Samples" folder. In this folder you will see a "FRC Java" folder. The line tracking sample is in there.
Unread 02-10-2011, 01:19 PM
pigpc1993 pigpc1993 is offline
AKA: Colin Feeney
FRC #3716 (WARP)
pigpc1993 is an unknown quantity at this point
My team has got our code working. If you guys need help drop us an email.
wasatchrobotics@gmail.com
Unread 02-10-2011, 01:47 PM
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
Here's my line sensing code:
package com.robototes.abomasnow;
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.Timer;
public class Main extends SimpleRobot {
    Driver robot = new Driver(1,2);
    LineSensorGroup lsg   = new LineSensorGroup(1,2,3);
    final int middle = 2;
    final int left = 1;
    final int right = 3;
    public void autonomous() {
        getWatchdog().feed();
        int last = middle;  //last line sensor value
        while(this.isEnabled() && this.isAutonomous()) {
            if(lsg.getMiddle()) {
                last = middle;
            } if (lsg.getLeft()) {
                last = left;
            } if (lsg.getRight()) {
                last = right;
            if (lsg.allAreOff()) {
                if (last == left) {
                    robot.arcadeDrive(0.4, 0.1);  //Forward and right*/
                    System.out.println("Left");
                } else if (last == middle) {
                    robot.arcadeDrive(0.5, 0);    /* Straight forward */
                    System.out.println("Forward");
                } else if (last == right) {
                    robot.arcadeDrive(0.4, -0.1);  /* forward and left */
                    System.out.println("Right");
            if (lsg.allAreOn()) {
                    robot.stop();
                    System.out.println("Stopping");
                    break;
            Timer.delay(0.05);
            this.getWatchdog().feed();
Driver is my own motor group controller, RobotDrive was too heavy for me
Unread 02-10-2011, 10:05 PM
AKA: Colin Feeney
FRC #3716 (WARP)
If you want some additional help read this.
http://decibel.ni.com/content/servle...20Tutorial.pdf
It talks about labview but it can really be applied to any language. A digital input, which the photoswitch is, returns either a true or false depending up what it is calibrated too. True if its the line, false if it isn't.
